Help.
Have bought the Mionix 8200 . Feels great to hold. Quite simply the best.
However, ran into what clearly is a software and firmware problem.
Upon first installation of plug and play, it worked perfectly.
I tried to install the software, but it didn't work. The progress bar stuck at 0% throughout.
So I tried to install the firmware, which was a big mistake. Now the scroll doesn't work, the side DPI indicators are blinking in sequence, and holding down left click+dragging around causes the mouse to pause.
The software still doesn't install.
Has anyone ran into such problems?!
https://linustechtips.com/topic/191259-problems-with-minox-8200/
Try deleting everything on your computer that is mionix and has to do with your mouse, and start over. There might be conflicting versions of something somewhere
Specs: 4790k | Asus Z-97 Pro Wifi | MX100 512GB SSD | NZXT H440 Plastidipped Black | Dark Rock 3 CPU Cooler | MSI 290x Lightning | EVGA 850 G2 | 3x Noctua Industrial NF-F12's
Bought a powermac G5, expect a mod log sometime in 2015
Corsair is overrated, and Anime is ruined by the people who watch it
https://linustechtips.com/topic/191259-problems-with-minox-8200/#findComment-2585759
Right.
So I finally got it to work.
Software installed and firmware upgraded.
A new problem rose.
After shutdown, turns out that at the click of any mouse button, the pc starts itself.
I tried unchecking the "wake computer" setting in the mouse settings under control panel.
This has not been successful.
Your advise would be most appreciated.
My pc specs:
w7 ultimate
i7 4771
ASRock z87 mitx
samsung 840 128ssd
https://linustechtips.com/topic/191259-problems-with-minox-8200/#findComment-2612797
Right.
A new problem rose.
My pc specs:
w7 ultimate
i7 4771
ASRock z87 mitx
samsung 840 128ssd
You most likely have to disable it in bios.
https://linustechtips.com/topic/191259-problems-with-minox-8200/#findComment-2612891
Right....
F2 and DEL brings me both to the UEFI menu...
Under which section do I look for that setting?
I don't know what your UEFI looks like but according to a Google search I would imagine you would find the settings under "Boot" or "Security". Look for something to do with "USB", "wake-up", etc.
https://linustechtips.com/topic/191259-problems-with-minox-8200/#findComment-2616224
