I have been Getting blue screens, I don't know why. when I turn my computer on after a thing pops up saying that my computer had an error and I hit more details and I get this.
Problem signature:
  Problem Event Name: BlueScreen
  OS Version: 6.1.7600.2.0.0.256.1
  Locale ID: 1033
Additional information about the problem:
  BCCode: a0000001
  BCP1: 0000000000000005
  BCP2: 0000000000000000
  BCP3: 0000000000000000
  BCP4: 0000000000000000
  OS Version: 6_1_7600
  Service Pack: 0_0
  Product: 256_1
Files that help describe the problem:
  C:\Windows\Minidump\080114-22401-01.dmp
  C:\Users\Donovan\AppData\Local\Temp\WER-47439-0.sysdata.xml
if that can help anyone help me then great otherwise I have no clue. Should I bring it in to a repair place? I custom build the PC so it might just be I am bad at it.
Current system CPU: Intel 4670k    MotherBoard: Asus z87-C   RAM: 12GB 1333mhz GPU: Sapphire AMD r9 290    Case: Corsair 200R    Storage: 250gb Sandisk SSD, 1tb segate barracuda HDD PSU: Corsair RM 850 Cooling: Corsair h100i No over clock
https://linustechtips.com/topic/190011-blue-screen-help/
temps?
it looks like GPU trouble
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/190011-blue-screen-help/#findComment-2559504
I don't have temps but the most resent time it has happened I was watching youtube, so it wasn't really doing anything.
https://linustechtips.com/topic/190011-blue-screen-help/#findComment-2559515
Do you have any loose computer parts? Make sure your RAM and GPU are all the was in. Also make sure there are no loos cable connections.
https://linustechtips.com/topic/190011-blue-screen-help/#findComment-2559521
temps?
https://linustechtips.com/topic/190011-blue-screen-help/#findComment-2559522
youtube you say
can you disable hardware acceleration for flash?
https://linustechtips.com/topic/190011-blue-screen-help/#findComment-2559526
youtube you say
how do i do that? lol I feel Kind of stupid.
https://linustechtips.com/topic/190011-blue-screen-help/#findComment-2559539
https://forums.adobe.com/thread/891337
https://linustechtips.com/topic/190011-blue-screen-help/#findComment-2559548
I do not have the option for settings
https://linustechtips.com/topic/190011-blue-screen-help/#findComment-2559557
you need to right click on the link and open another tab as described in the FAQ
https://linustechtips.com/topic/190011-blue-screen-help/#findComment-2559564
ok done.
https://linustechtips.com/topic/190011-blue-screen-help/#findComment-2559582
ok done.
monitor and see if it still crashes
https://linustechtips.com/topic/190011-blue-screen-help/#findComment-2559585
download Bluescreenview
http://www.nirsoft.net/utils/blue_screen_view.html
Run it, and post a screenshot of what it spits out please.
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
https://linustechtips.com/topic/190011-blue-screen-help/#findComment-2559598
