Suggest me a Build!
All that I will have on the SSD would be my OS, maybe 3-5 games (won't take more than 60GB), and some programs, everything else will be on the 1TB Samsung drive that I have.
Perfect still I think we can squeeze a little more quality out of this budget give me a minute....
CPU: AMD FX-6350 3.9GHz 6-Core Processor ($139.99 @ Amazon)
Motherboard: Asus M5A97 R2.0 ATX AM3+ Motherboard ($84.99 @ Newegg)
Memory: Kingston HyperX 8GB (2 x 4GB) DDR3-1600 Memory ($79.99 @ Amazon)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive ($80.99 @ NCIX US)
Video Card: Sapphire Radeon R9 280X 3GB Dual-X Video Card ($259.99 @ Newegg)
Case: Enermax ECA3290A-G ATX Mid Tower Case ($49.99 @ NCIX US)
Power Supply: SeaSonic 520W 80+ Bronze Certified Semi-Modular ATX Power Supply ($75.98 @ Newegg)
Total: $771.92
Generated by PCPartPicker 2014-08-01 02:28 EDT-0400
I spend a little bit more then you but the psu is stronger tho its lower wattage so when you upgrade you need to upgrade that probably as well. It's really not that much more expensive...and I upgraded your CPU....that little bit of extra push for your cpu intensive work like rendering and editing will show then.
or
Power Supply: XFX ProSeries 750W 80+ Silver Certified Semi-Modular ATX Power Supply ($100.00 @ NCIX US)
Total: $795.94
Generated by PCPartPicker 2014-08-01 02:31 EDT-0400
This verison is just a little bit more expensive and when you go this route if you decide to upgrade your video card and cpu you wont have to upgrade the PSU.
Overall the choice is yours.
