Just ditch that crap. I couldn't stand it.
But if you really like it, reinstalling it probably will the issue. That happened to me when I used it. Reinstalled and it worked again.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/189731-razer-surround-glitch/#findComment-2555522
It worked pretty well with my old heaphones (SHP2700).
I can't re-install it because i got it when razer was giving it out for free, or can I?
Samung Tab S 8.4
https://linustechtips.com/topic/189731-razer-surround-glitch/#findComment-2555571
