CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($299.58 @ Micro Center)
Thermal Compound: Arctic Silver 5 High-Density Polysynthetic Silver 3.5g Thermal Paste ($6.74 @ Amazon)
Motherboard: Gigabyte GA-G1.SNIPER Z97 ATX LGA1150 Motherboard ($148.99 @ Newegg)
Memory: Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-1600 Memory ($179.99 @ Newegg)
Storage: Samsung 840 EVO 1TB 2.5" Solid State Drive ($444.93 @ Amazon)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive ($109.99 @ Newegg)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive ($99.99 @ Amazon)
Video Card: Gigabyte GeForce GTX 780 Ti 3GB WINDFORCE Video Card ($725.91 @ Newegg)
Case: Corsair 900D ATX Full Tower Case ($300.98 @ Micro Center)
Power Supply: EVGA SuperNOVA 1000 P2 1000W 80+ Platinum Certified Fully-Modular ATX Power Supply ($169.99 @ NCIX US)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($16.98 @ OutletPC)
Monitor: Asus VS239H-P 23.0" Monitor ($155.43 @ Amazon)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm Fan ($24.99 @ Newegg)
Case Fan: Cooler Master R4-S4S-10AK-GP 60.9 CFM 140mm Fan ($4.99 @ Newegg)
Fan Controller: NZXT SENTRY 3 Fan Controller ($31.99 @ SuperBiiz)
Keyboard: Corsair Vengeance K70 Wired Gaming Keyboard ($114.99 @ Amazon)
Mouse: Corsair Raptor M45 Wired Optical Mouse ($49.99 @ Newegg)
Headphones: Logitech G930 7.1 Channel Headset ($99.99 @ Amazon)
Speakers: Logitech Z623 200W 2.1ch Speakers ($118.99 @ Amazon)
Other: Alphacool NexXxoS ST30 Full Copper Slim Profile Quad 120mm Radiator ($84.99)
Other: Alphacool NexXxoS UT60 Full Copper Quad 120mm Radiator ($129.99)
Other: (x2) XSPC 4 x 120mm Radiator Gasket - 3mm ($8.00)
Other: Alphacool NexXxoS ST30 Full Copper Slim Profile Single 140mm Radiator ($54.99)
Other: EK Supremacy Universal CPU Liquid Cooling Block - Acetal (EK-Supremacy - Acetal) ($70.99)
Other: Bitspower Water Tank Z-Multi 400 Inline Reservoir - Ice Red (BP-WTZM400P-IRDBK) ($56.95)
Other: EK D5 X-Top Pump Top w/ D5 Vario Pump - Black Acetal (EK-D5 Vario X-TOP (incl. pump)) + Sleeved Cabling ($121.98)
Other: IandH Silver KillCoils - Antimicrobial .999 Fine Silver Tubing / Reservoir Strip ($6.99)
Other: Koolance G1/4" Brass Inline Drain Valve Fitting - 4 Port (VLV-XUTX4B) ($11.99)
Other: PrimoChill Vortex Black POM Visual Flow Indicators - Blood Red Faceplates (FI-V-BR) ($22.99)
Other: EK Gigabyte GeForce 780 GTX WF3 VGA Liquid Cooling Block - Nickel + Acetal (EK-FC780 GTX WF3 - Acetal+Nickel) ($116.99)
Other: EK Gigabyte GTX 780 WF3 Backplate - Black (EK-FC780 GTX WF3 Backplate - Black) ($30.99)
Other: PrimoChill PrimoFlex Advanced LRT Tubing 3/8"ID x 1/2" OD - 10ft Retail Pack - Bloodshed Red (PFLEXA10-12-R) w/ Free Sys Prep ($24.99)
Other: EVGA G2/P2 Black Power Supply Cable Set (Individually Sleeved) (Black) ($89.99)
Other: Logisys 15" Deluxe Sound Activate Cold Cathode Kit - White ($20.98)
Other: Logitech - Gaming Pad F310 ($24.99)
Other: IKEA ALEX Drawer unit, black-brown ($79.99)
Other: IKEA TORNLIDEN Table top, black-brown ($49.99)
Other: Bitspower Matte Black Quick-Disconnected Male w/ Inner G1/4 (BP-MBQDMIG14)83 ($83.80)
Other: Bitspower Matte Black Quick-Disconnected Female w/ G1/4 Thread (BP-MBQDFG14) ($94.00)
Other: (x13) Bitspower G 1/4 Thread 3/8" ID x 1/2" OD Compression Fitting - Matte Black (BP-MBCPF-CC2) ($116.35)
Other: Bitspower G1/4 Thread 3/8" ID x 1/2" OD 90-Degree Rotary Compression Fitting - Matte Black (BP-MB90R2LCPF-CC2) ($18.99)
Other: PrimoChill - Threaded G 1/4 Funnel - Black (PC-GF-BK) ($9.49)
Total: $4807.66
Generated by PCPartPicker 2014-07-29 12:34 EDT-0400
Also how do you make a drain port that's always connected and what parts do you need to do this?
Res>flow monitor>pump>drain port t>basement rad>gpu>cpu>back rad> top rad>res.
If you've previously won the build off please pm me so we can get something worked out.
https://linustechtips.com/topic/188501-custom-water-cooling-loop/
You've made like 7 topics on this. Chill.
The drain port should just be on the bottom... If your loop is sealed you should be able to open it when the pump is not running and nothing will come out until you open a place for air to come in.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
*ultra snip*
Great choice of components!
Your pump has to come directly after your res and it has to be above your pump. Skip the 140mm back rad entirely, it's just more tubing, fittings etc. Two quad 120mm rads is more than enough for a CPU + GPU(s).
For the drain valve use this http://www.frozencpu.com/products/14595/ex-tub-1034/Bitspower_G14_Mini_Valve_-_Black_Sparkle_BP-MVV-BKBK.html somewhere at the bottom of your loop. You can connect it with a T-line fitting between two components and just have it closed with a stop plug on the opening when you're not using it.
Cool it on the post tho.
Bert & Ernie before squirting spermie.
In regards to your comment to posting this "7" times which I will ignore my reasoning behind making another post was to get a divsity of opinions along with making it easier on people that are responding to this topic. My previous topics did not have water cooling or lighting in them. I have been getting opinions to make this build the most stable and solid I can. so excuse me for trying to make it easier on people who are responding. anyways now that that's cleared up :P thank you so the drain port will act like equal pressure do I need a valve on it?
http://linustechtips.com/main/topic/188341-final-outcome-suggestions-welcome/#entry2535527
http://linustechtips.com/main/topic/188445-i-need-someone-good-at-watercooling/#entry2537024
Just a tip, making more posts makes it harder for people trying to respond since they have to keep tracking your new posts.  :)  In regards to a diversity of opinions. Sending multiple topics will actually get you less focused help. What I mean is that people who know about watercooling will go to the watercooling section and look at the topics while people who see it on the recent posts list may know nothing and make bad recommendations. I would check out overclockers.com for very experienced watercoolers.  :)
Onto your question. I'm not sure what an equal pressure valve is but as long as it is at the bottom of your loop and you open the top of you res to let air in, it will drain just fine.
I think i got it and in regaurdes to multiple posts I actually thought about that after I posted it. I will just update the current post in the future and reply with update.
why not stick at UT60 at the top?
CPU i7 3770K@4.6Ghz Motherboard  Asus Maximus V Extreme Ram 4x4GB Corsair Dominator Platinum @ 1866Mhz GPU 3-Way Sli EVGA Gtx 780 //Core@1.2Ghz/Mem@7Ghz// PSU Corsair Ax1200i Storage OS 2xSamsung 840 Pro 128GB // 2xOCZ Vertex 4 128GB // 2xWD Red 4TB Keyboard Corsair K70 Mouse Steelseries Xai Cooling Custom Dual Loop Case Corsair 900D
the 45mm doesnt work?
im guessing theres no waterblock for g1 yet?
G1 power supply?
haha, g1 mobo
No its not that...just changing the casing and the water cooling layout to save a little money is all :) I like the enthoo primo (black) better anyways and have some ideas for it, plus it will match my fiance's since she will have the Phanteks Luxe.
