https://linustechtips.com/topic/188390-pc-build-help/#findComment-2536270
budget?
CPU: AMD FX-8120 | CPU Cooler: Thermaltake Contac 30 | Motherboard: GIGABYTE GA-990FXA-UD3 | Memory: Kingston 16GB (4 x 4GB) DDR3-1333 | Storage: WD 1TB | GPU: Gigabyte Radeon HD 7870 | Case: Thermaltake Chaser MK-I | PSU: Thermaltake Black Widow 850W
https://linustechtips.com/topic/188390-pc-build-help/#findComment-2536289
Hey guys. Im in a small dilemma. I'm planning on buying a desktop and I really want it for live streaming to twitch, playing a lot of awesome games, and doing some editing on it. I'm planning on
Case: corsair 760t est $180
Cpu: intel 4790k processor est. $330
Cpu Fan: thermaltake frio est. $65
Motherboard: ASUS Z-97-A est. $150
RAM: corsair vengeance 16gb est. $150
SSD: crucial mx100 256gb est $115
HDD: seagate barracuda 2tb est. $85
PSU: corsair cx 750 watt est $65
GPU: nvidia EVGA gtx 780 est. $520
And to top it off an asus vg248qe monitor est. $250. This all costs around 1800 or 2000 dollars. Any suggestions on how to cut price an get similar performance or and suggestions on getting some different parts. Thanks for any and all help. All prices estimated from amazon
https://linustechtips.com/topic/188390-pc-build-help/#findComment-2536324
around 4thousand
http://pcpartpicker.com/p/T4HH7P not sure if this is ultimate or just overkill
i made an error, changed the video cards to reference ones
Edited by Admiaczking
https://linustechtips.com/topic/188390-pc-build-help/#findComment-2536352
4 grand? Can I have your job?
maybe he saved up
https://linustechtips.com/topic/188390-pc-build-help/#findComment-2536363
looks real good for the stuff you want it for :D
https://linustechtips.com/topic/188390-pc-build-help/#findComment-2536365
@Msxander99 the 780's will be quiet and cooler than dual 290s but i think dual 290s will do better since they have more VRAM which is important in a 4K build. you could go 3-way SLI/Crossfire as well if you changed a few things, most of that part list is suggestions but i strongly recommend graphics cards with a lot of memory, 4 GB+
https://linustechtips.com/topic/188390-pc-build-help/#findComment-2536373
if i were to use the evga 780 6gb superclcoked card and put a custom ek liquid cooler on it would i be able to over clock it to get better performance then the 780ti?
https://linustechtips.com/topic/188390-pc-build-help/#findComment-2536399
probably, i'm not entirely sure though
https://linustechtips.com/topic/188390-pc-build-help/#findComment-2536469
around 4thousand
Is that 4K budget including your monitor and custom loop or is that only for the CPU, GPUs, MB, Ram, etc...?
Yeah I think I'm gonna just go with what I picked
I would look at a better PSU.
CPU: Intel I7-4790k | MOBO: Asus Sabertooth Z97 Mark 1 | Ram: Corsair Vengance 32GB 1600hz | GPU: EVGA GTX980 Reference
PSU: Corsair EVGA G2 850W  | SSD: Intel 730 Series 480GB, Kingston SSDNow V300 120GB | HDD: WD Black 1TB
 CPU Cooler: Corsair H105 | Case: Corsair 760T (White) | Peripherals: (2)Asus VS247H-P, Corsair M65, Corsair K70 RGB w/ Brown Switches
https://linustechtips.com/topic/188390-pc-build-help/#findComment-2536744
