i'm not sure what brand is best, once you choose a size and approximate thickness and maybe fin density it's probably all down to budget and looks really. as for if that will be enough i think so, the general rule of thumb is 1x120 per component which means in theory a triple 120 would work but for a little bit more head room you could add 1x120 or 2x120 to that and you'd most likey be able to do anything you could want with that setup so i think the total of 120x11 will be A LOT more than enough
https://linustechtips.com/topic/188339-radiator-questions/#findComment-2535532
Alphacool makes some incredible full copper radiators, they are fairly low FPI, but come in thicknesses up to as high as 80mm.
Case: Corsair Carbide 300R CPU: Intel i7 2600k CPU Cooler: Cooler Master Hyper 212 Evo w. 2x Cooler Master Blade Master 120mm Mobo: ASUS Maximus IV Gene-Z RAM: 2x4GB Kingston HyperX 1600mhz GPU: Gigabyte GTX670 SSD: 256GB Samsung 830 HDD: Random WD 500GB (It's old) PSU: Corsair Professional Series Gold AX750
Case: Corsair Obsidian 750D CPU: Intel Core i7-4790K @ 4.7 GHz CPU Cooler: Corsair H110 w. 2x Noctua NF-A14 Industrial in pull Mobo: ASUS Maximus VII Hero RAM: 2x8GB Corsair Vengeance Pro 2400 MHz GPU: ASUS GTX780 DCUII SSD: 250GB Samsung 840 Evo HDD: WD Green 3TB PSU: Corsair AX860i
Monitor: BenQ 24" XL2410T Keyboard: Logitech G19 Mouse: Logitech G500 Speakers: Logitech Z-5500 Digital Headphones: Beyerdynamic Custom One Pro
https://linustechtips.com/topic/188339-radiator-questions/#findComment-2535541
this reminds me, that's another thing you're going to want to consider is the material. try to keep it all one metal so match the the rad to your blocks. i think nickle and copper play nice though so you should be ok there if your blocks are nickle or nickle plated
https://linustechtips.com/topic/188339-radiator-questions/#findComment-2535554
alright thanks
https://linustechtips.com/topic/188339-radiator-questions/#findComment-2535559
i was kinda thinking ek because the cosmos 2 doesnt support the monsta
You can always go for the 45mm or the 60mm rads instead, you shouldn't need the monsta. Which EK radiators are you looking at?
With 2 quads and 1 triple you can go with whatever thickness you want really and still be okay. The length alone is a ton of surface area.
Edit: Also, while it is true that more FPI provides more surface area to dissipate the heat with, I would always go for lower FPI thicker radiators, personally. Lower FPI makes it easier for fans to push / pull air through and allows you to run fans with less static pressure and at a lower RPM (for silence).
https://linustechtips.com/topic/188339-radiator-questions/#findComment-2535696
http://hardwarelabs.com/nemesis/nemesis-products/nemesis-gtx/nemesis-480gtx
yea bought the cosmos 2 and then immediately switched to 900D. Talked to the coolermaster guys at Computex and hopefully they listened to some of my suggestions.
CPU i7 3770K@4.6Ghz Motherboard  Asus Maximus V Extreme Ram 4x4GB Corsair Dominator Platinum @ 1866Mhz GPU 3-Way Sli EVGA Gtx 780 //Core@1.2Ghz/Mem@7Ghz// PSU Corsair Ax1200i Storage OS 2xSamsung 840 Pro 128GB // 2xOCZ Vertex 4 128GB // 2xWD Red 4TB Keyboard Corsair K70 Mouse Steelseries Xai Cooling Custom Dual Loop Case Corsair 900D
https://linustechtips.com/topic/188339-radiator-questions/#findComment-2536488
I really like my XT45's (240 and 360). Full copper and everything. I've also heard hardware labs has good rads though. Black ice GT is there babe I think. But I would go with that ever you think looks the best between the two.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/188339-radiator-questions/#findComment-2536512
i thought the nemesis is replacing it~ idk im running UT60s as well. i  think for my next build however is going to be with HWL
https://linustechtips.com/topic/188339-radiator-questions/#findComment-2536519
Hi i am looking to build a ultimate 4k rig and i would like to know which radiator brand is the best (if their is a best) and if 2 quads and 1 triple would be enough to cool a i7 4930k and 2 780ti with koolance water-blocks on them
-Thanks
Alphacool makes the best rads. The UT60 is a good sweet spot, it beats the competition when used with fans at low rpm and keeps up with the high fpi rads at high rpm.
The EK XTX series and BlackIce SR-1 are good too. There are multiple rad configs that can kill the heat on your CPU + GPU's. 2x 360, 360 + 480 would already be enough. Of course depending on how much you're willing to spend, the more rads = the lower the rpm you can run the fans at. You can get good temps, with insanely low noise.
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/188339-radiator-questions/#findComment-2536527
