I just built my first PC and at first I was having trouble with my monitor so I didn't really use it for much. Now that I just fixed the monitor and started using it I noticed that sometimes it restarts almost randomly. I say almost randomly because it turns off every time when I'm working on Revit and I use the 3D views but it also happened once when I was installing some drivers (and it wasn't the usual driver restart). Does anybody know what it might be?
Specs: gigabyte GA-Z97X-UD5H-BK (black edition), Geforce GTX 770, Intel core i7 4790k, 750 watt power supply, and windows 8.1.
https://linustechtips.com/topic/188165-help-with-my-pc/
I would try reinstalling the graphics drivers first. If that doesn't solve it then it could be more complicated of a problem to diagnose if it's not throwing any errors.
"Rawr XD"
https://linustechtips.com/topic/188165-help-with-my-pc/#findComment-2533198
Overheating possibly? What are your temps normally around when it happens?
https://linustechtips.com/topic/188165-help-with-my-pc/#findComment-2533215
I did go into the event logs and it said error but I couldn't really figure out what it was
https://linustechtips.com/topic/188165-help-with-my-pc/#findComment-2533217
It can't be overheating because I monitored the temps while I was doing the thing and they didn't change much (from 29 degrees C to like 34) so I think it might be more of a software problem or maybe even a motherboard problem but not the temp. (plus it was only using like 40% of the CPU)
https://linustechtips.com/topic/188165-help-with-my-pc/#findComment-2533239
I'd go and check to make sure everything is connected tightly. A loose power connector can cause restarts. To check if it's software I'd suggest starting up some hardware testing software (Memtest86, etc) and letting it run. If that doesn't cause a restart then it's software and I'd just do a clean install of whatever OS you are using.
https://linustechtips.com/topic/188165-help-with-my-pc/#findComment-2534811
  • 2 weeks later...
Post the error code on this forum.
We can help.
I still cant figure out the error code or how to upload the images, but I ran prime95 and as soon as I click ok for the torture test (small FFT) it turns off. Can it be my CPU or something that's causing the problem?
https://linustechtips.com/topic/188165-help-with-my-pc/#findComment-2693954
