on my laptop there's this really annoying thing that doesn't allow me to do basically anything. The webcam says it doesn't work and when i close it i see a cmd flash open then close. When i use google chrome is also decides to close it's self randomly.It's on windows 7 64 bit. Also i dont want to wipe the os if it going to fix it because i dont wanna buy a copy of windows 7. Thanks
https://linustechtips.com/topic/188154-class-not-registered/
easiest fix (lazy fix) create a new user account with Admin rights and see if that one works, if it does, go to users>old account> copy all folders like documents, movies etc. you want to keep over to the new user account.
CPU: R5 1600 @ 4.2 GHz; GPU: Asus STRIX & Gigabyte g1 GTX 1070 SLI; RAM: 16 GB Corsair vengeance 3200 MHz ; Mobo: Asrock Taichi x470; SSD: 512 gb Samsung 950 Pro Storage: 5x Seagate 2TB drives; 1x 2TB WD PurplePSU: 700 Watt Huntkey; Peripherals: Acer S277HK 4K Monitor; Logitech G502 gaming mouse; Corsair K95 Mechanical keyboard; 5.1 Logitech x530 sound system
 01000010 01101001 01101110 01100001 01110010 01111001 00100000 01100100 01101111 01100101 01110011 01101110 00100111 01110100 00100000 01101101 01100001 01101011 01100101 00100000 01111001 01101111 01110101 00100000 01110000 01110010 01101111 00101110
https://linustechtips.com/topic/188154-class-not-registered/#findComment-2533104
i don't know how to fix your problems but as for re installing  the os if it came pre-loaded with windows 7 there should be a recovery partition which will bring it back to factory defaults which might fix your problem assuming this has just begun recently. to enter the partition and factory reset the computer you will most likely need to press a specific f key or combination of keys which probably isn't listed with the keys to enter the bios or other setting son boot up, you'll have to look this combination up based on your computers brand or you might be able to consult a users manual (or just try everything). alternatively assuming this has just started very recently you might be able to return the computer to an earlier date even as early this morning. but anyways what do i know, maybe someone else will have a solid fix that doesn't require you to go through all that
https://linustechtips.com/topic/188154-class-not-registered/#findComment-2533134
Yeah, a system recovery to an earlier state might fix it if it started happening recently. as for the recovery partition, it works if you have one, but a lot of prebuilds don't come with those partitions anymore.
https://linustechtips.com/topic/188154-class-not-registered/#findComment-2533161
well i think laptops do, at least my last one did although that was 2 or 3 years old so you could be right
https://linustechtips.com/topic/188154-class-not-registered/#findComment-2533205
i tried the lazy fix but i cant make a new one but ill try the restore point thing
what prevented you from the creating a new user account?
https://linustechtips.com/topic/188154-class-not-registered/#findComment-2536583
