Modding Radeon 7950
Go to solution Solved by juretrn,
Short answer : no.
Power delivery is made for those cards with 6+8 differently than for those with 6+6.
7950 is also a cut down version of the 7970 chip. Cannot be flashed into one, it's physically different.
So this is a far out idea but I am wondering if this is possible. On a gen2 reference card of the MSI Radeon 7950 it has two 6pin power. While on some other 7950s they had a 6 + 8 indicating it might be built on a 7970 PCB and then the 7950 could be flashed to full power of a 7970. The main question is, is it possible to remove one 6 pin and add the 8 pin connection as the PCB has solder points for the 8 pin, and then have more power going to the card. Then flash 7970 bios on it. This is an extremely weird question but I mean would it work. Is it possible at all, or will the card just kill itself?post-109268-0-76700400-1406582781_thumb.
https://linustechtips.com/topic/188086-modding-radeon-7950/
Short answer : no.
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
https://linustechtips.com/topic/188086-modding-radeon-7950/#findComment-2532058
Its possible, but A, its terribly difficult to do without destroying your card. B, it voids your warranty. C, itn would have to be a card that has a duel bios switch to flash the bios with and i don't believe reference 7950's have that.
So i wouldn't do it...
https://linustechtips.com/topic/188086-modding-radeon-7950/#findComment-2532065
1. You cannot flash a HD 7950 to a HD 7970. The extra shaders are not simply disabled, like what happened on the HD 6970 / 6950, but instead they are completely severed off.
2. The two solder points for the extra two pins are present, but the PCB trace and the where it connects to on the rest of the card could have been removed.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/188086-modding-radeon-7950/#findComment-2532613
