Are these good parts?
Solved by RainbowPee,
If the WD caviar blue is gonna be your boot drive/game drive. DO NOT GET THAT HD! blue drives are power saver slow drives. get a 120GB Samsung Evo Pro as the boot drive and a 1-2 TB WD Caviar Black as storage and gaming drive.
I'm pretty sure you're mixing up blues and greens. You can run on the blue just fine. For the future however I'd recommend a 840 Evo for an upgrade.
Looks solid. I would get Arctic MX-4 though for cooling paste. It's incredible thermal paste. I would also go with @floydkid85 's suggestion. Also http://uk.pcpartpicker.com/part/intel-cpu-bx80646i54690k is only 3 pounds more and expensive and is much much better (Devils canyon > Haswell)
He doesn't need to spend and extra $15 for 2C of cooling.
