Hi i am looking to build an ultimate gaming, water cooled pc and i need help to see if all my parts are good, and compatible
fist off
http://www.aquatuning.de/wasserkuehlung/radiatoren/radiatoren-aktiv/12340/alphacool-nexxxos-xt45-full-copper-360mm -(single triple rad)
http://www.aquatuning.de/wasserkuehlung/radiatoren/radiatoren-aktiv/12349/alphacool-nexxxos-xt45-full-copper-480mm -(2 quad rads)
http://koolance.com/nozzle-single-compression-for-10mm-x-16mm-3-8in-x-5-8in -fittings
http://www.ncix.com/detail/primochill-primoflex-advanced-lrt-bloodshed-0b-78757-1198.htm tubing
http://www.ncix.com/detail/koolance-cpu-380i-water-block-intel-4d-88411.htm waterblock
http://www.ncix.com/detail/swiftech-8w-pwm-spl-8-way-pwm-3b-82243.htm fan controller
http://www.phobya.com/eng/phobya.html -(reservoir
phobya 150 gold plated.
about 12 extra noctua fans for the radiators
all this will be cooling my cpu and 2 780ti superclocked http://koolance.com/video-card-vga-nvidia-geforce-gtx-titan-water-block-vid-nxttn2  -(gpu blocks)
will this be enough? or overkill? and are all my parts good for cooling sli 780 ti's and a 4930k
-stefan
https://linustechtips.com/topic/187815-water-cooling-help/
-stefan
All your parts work with each other. You'll having ballin low temps with a 360 + 480 cooling a 4930K and 2 780 ti's. Enjoy! Have you looked at EK for the waterblocks? Also could you tell me what case you're using?
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/187815-water-cooling-help/#findComment-2529615
fist off
-stefan
The one thing i am not seeing here is the pump. I hope it is a D5 or something with similar flow rate and pressure head. Not sure if your case can handle 1 or 2 420mm radiators but i would switch from 120mm radiators to 140mm radiators if not then the two 480mm are enough.
A water-cooled mid-tier gaming PC.
https://linustechtips.com/topic/187815-water-cooling-help/#findComment-2531411
the case is a cosmos 2 ultra
https://linustechtips.com/topic/187815-water-cooling-help/#findComment-2533052
It says 3x120mm on top how are you getting a 480mm in this? I damn well know you won't get the 420mm in as i suggested.
If you really want to do a big radiator and like to mod and you are a bit loony, check this nut at what he did. Also, that crazy English fella on OverclockersUK has stated that it maybe time for this to become the next step in ultimate watercooling. :(
I am personally looking into getting a case made from aluminium or steel which ever is cheapest here by me to fit one of those radiators in it for my next build.
https://linustechtips.com/topic/187815-water-cooling-help/#findComment-2533380
i might try to get "fancy" with the mounting because i really love the cosmos 2 but i might get a 900d instead because i know it has support for all those rads
https://linustechtips.com/topic/187815-water-cooling-help/#findComment-2533426
yea decided going watercooling after i got my cosmos 2, immediately switched to 900d and never looked back.
why not use ut60s?
CPU i7 3770K@4.6Ghz Motherboard  Asus Maximus V Extreme Ram 4x4GB Corsair Dominator Platinum @ 1866Mhz GPU 3-Way Sli EVGA Gtx 780 //Core@1.2Ghz/Mem@7Ghz// PSU Corsair Ax1200i Storage OS 2xSamsung 840 Pro 128GB // 2xOCZ Vertex 4 128GB // 2xWD Red 4TB Keyboard Corsair K70 Mouse Steelseries Xai Cooling Custom Dual Loop Case Corsair 900D
https://linustechtips.com/topic/187815-water-cooling-help/#findComment-2536531
