h110 temps
Go to solution Solved by Antistatic12,
That's fine. It would be bad if it didn't.
i just overclocked my cpu to 4.4ghz on 1.2 volt and my temps were around 62/63C while running prime95. when i stopped strees testing my temps dropped to 33C in like 10/15 seconds, is that normal?
msi z97m gaming - i5 4690k @4.4ghz 1.2V corsair h110 powercolor r9 290x pcs+ - 8GB corsair vengeance dual channel @2133mhz - thermaltake smart power se 730watts - intel 530 series 240GB ssd seagate 1tb 7200rpm - corsiar obsidian 350D - 2x enermax tb silence 140mm - logitech x-530 - sony mdr xb600 - medion 24'' 1080P cm storm quickfire tk white edition with cherry mx red cheap but awesome mouse #GloriousPaintMasterRace
https://linustechtips.com/topic/187800-h110-temps/
CORSAIR RIPPER: AMD 3970X - 3080TI & 2080TI - 64GB Ram - 2.5TB NVME SSD's - 35" G-Sync 120hz 1440P
MFB (Mining/Folding/Boinc): AMD 1600 - 3080 & 1080Ti - 16GB Ram - 240GB SSD
Dell OPTIPLEX:  Intel i5 6500 - 8GB Ram - 256GB SSD
PC & CONSOLE GAMER
https://linustechtips.com/topic/187800-h110-temps/#findComment-2528165
