My GA-X79-UD3 will not pass the screen that lets you enter the bios and boot menu, when you first stat the computer.  I have already tried clearing the simos, checked all the connections and have no idea what else to do.  But it has also given me problems with sleep mode, where on wake up it will just begin to cycle on and off until i have to unplug it from the wall.  any help would be much appreciated?
https://linustechtips.com/topic/18758-mobo-problems/
Try this: take the battery out and put it in again (EDIT: this will reset the BIOS)
CPU: Intel Core i7 4790K @ 4.4GHz (cooled by Corsair H110) Motherboard: ASUS Maximus VI Formula RAM: 16GB DDR3 1600MHz CL9 | GPU: ASUS GTX780TI-DC2OC-3GD5 Case: NZXT Phantom 630 Storage: Samsung 840 Pro 128GB + 3 x WD Black 500GB  + WD Black 1TB + WD Black 2TB + Kingston V300 120GB PSU: SeaSonic Platinum 660W Monitors: 3 x Iiyama ProLite XU2390HS-1 Keyboard: Logitech G910 Orion Spark Mouse: Logitech G502 Protheus Spectrum Mousemat: Steelseries QcK Heavy (40x45) Headset: Kingston HyperX Cloud II Speakers: Logitech Z906
https://linustechtips.com/topic/18758-mobo-problems/#findComment-219650
That did not work.
Than it's a software fault, reinstalling Windows isn't an option?  :unsure:
https://linustechtips.com/topic/18758-mobo-problems/#findComment-219765
No I think you were right.  It decided to work after I restarted it again after i did what you said.
You're welcome  ;)
https://linustechtips.com/topic/18758-mobo-problems/#findComment-220478
