OK I'm make this in the prodigy
I just post the pc part picker
http://ca.pcpartpicker.com/user/Brettrose/saved/trkgXL
Do you think this will work.?
And is this the best way to do this build?
Suggestions?
Any ways to make this cheaper?
Budget Around 1250 ( and no part can be over 600 $ bank doesn't let me spend that much a week)
post-90221-0-21000000-1406424008_thumb.p
https://linustechtips.com/topic/187254-first-time-itx-build/
I'd go with a stock cooler on the 780, since there wont be a whole lot of air flow in a mITX case like the prodigy
INTEL CORE I5 4670K | NVIDIA GTX 980 | NOCTUA NH-L9i | GIGABYTE GA-Z97X-SLI | KINGSTON 120GB V300
CM STORM QUICKFIRE TK | BENQ XL2420TE | ROCCAT SAVU | FRACTAL DEFINE R4
https://linustechtips.com/topic/187254-first-time-itx-build/#findComment-2519658
budget?
ocing?
uses?
use the quote button if you want my help
Specs
https://linustechtips.com/topic/187254-first-time-itx-build/#findComment-2519722
A few suggestions. A locked cpu to go along with the H97 motherboard. No need for an aftermarket cpu cooler. No need for DDR3-2400 memory, DDR3-1600 will do just fine. An ssd - some kind of storage is needed. A better, lower wattage, and shorter psu.
CPU: Intel Core i5-4690 3.5GHz Quad-Core Processor  ($227.99 @ NCIX)
Motherboard: MSI H97I AC Mini ITX LGA1150 Motherboard  ($128.98 @ Newegg Canada)
Memory: A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1600 Memory  ($82.99 @ Canada Computers)
Storage: Sandisk Solid State Drive 128GB 2.5" Solid State Drive  ($64.95 @ Vuugo)
Video Card: Gigabyte GeForce GTX 780 3GB WINDFORCE Video Card  ($579.98 @ Newegg Canada)
Case: BitFenix Prodigy (Black) Mini ITX Tower Case  ($64.99 @ Memory Express)
Power Supply: Silverstone Strider 600W 80+ Silver Certified Fully-Modular ATX Power Supply  ($109.99 @ Memory Express)
Total: $1259.87
Generated by PCPartPicker 2014-07-26 20:31 EDT-0400
https://linustechtips.com/topic/187254-first-time-itx-build/#findComment-2519729
budget?1250
ocing? None
uses? Gaming browsing
actually what @borb said is fine however id switch the 780 for a 290 and save some money
Specs
https://linustechtips.com/topic/187254-first-time-itx-build/#findComment-2520113
