Whenever I plug in the power cable to the wall, the PC automatically turns on but can't turn off unless you hold the button, but whenever you let go of the power button, the PC just turns back on. It doesn't boot to a BIOS when it turns on automatically either. The monitor just says 'Going to sleep'. Please help.
Edit: there is no manual off switch thing on the PSU.
https://linustechtips.com/topic/186834-pc-power-button-problems/
specs
https://linustechtips.com/topic/186834-pc-power-button-problems/#findComment-2514030
then try replacing the switch.
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
https://linustechtips.com/topic/186834-pc-power-button-problems/#findComment-2514050
It's an old motherboard with a Pentium 4 on it. Also, the PSU is an off brand that came w/ the case. But the PSU isn't the problem.
check in the bios settings if the system is enabled to restart when power is lost
https://linustechtips.com/topic/186834-pc-power-button-problems/#findComment-2514054
