link: http://www.nexusmods.com/skyrim/mods/19/?
I want to know if this only fixes bugs.
I also assume it wont interfere with:
-cliamtes of atmriel
-2k textures
-quality word map
-sky UI
CPU: Ryzen 5500 GPU: RX 6800 RAM: DDR4 3200MHZ 48GB (2x8+2x16 GB)  MOBO: MSI B450-A PRO Display: 4k120hz with freesync premium.
https://linustechtips.com/topic/186792-skyrim-unofficial-patch-for-bug-fixing/
It shouldn't affect mods, unless you install one which alters some of the vanilla game files.
The ones you linked should work fine, i personally have ~100 mods installed at any given time.
AMD Phenom II 965 C3 @3.8GHz / Scythe Ninja III / 8GB Crucial Ballistix Sport / MSI 990FXA-GD65 / MSI R9 270x 4GB / EVGA 600W Bronze / Asus Xonar DG
My sky UI is broke as hell so i uninstalled that a while back, its fine with 2k textures in fact its fine with my 4k textures, nothing impacts the world quality map, and i dont use climates of tamerial because it causes all sorts of crap with other mods.
Listen if you care.
