PCPartPicker part list: http://pcpartpicker.com/p/Pp6bTW
Price breakdown by merchant: http://pcpartpicker.com/p/Pp6bTW/by_merchant/
CPU: Intel Xeon E3-1226 V3 3.3GHz Quad-Core Processor  ($221.98 @ SuperBiiz)
Motherboard: ASRock H81M-ITX Mini ITX LGA1150 Motherboard  ($65.38 @ Newegg)
Memory: A-Data XPG V1.0 8GB (1 x 8GB) DDR3-1600 Memory  ($72.99 @ Amazon)
Storage: Seagate  1TB 3.5" 7200RPM Hybrid Internal Hard Drive  ($77.99 @ Amazon)
Video Card: Sapphire Radeon R9 280X 3GB Dual-X Video Card  ($259.99 @ Newegg)
Case: Antec ISK600 Mini ITX Tower Case  ($59.95 @ Mwave)
Power Supply: Thermaltake 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($59.99 @ Newegg)
Monitor: AOC i2267Fw 60Hz 22.0" Monitor  ($129.99 @ Amazon)
Wireless Network Adapter: Patriot PCUSBW1150 802.11a/b/g/n USB 2.0 Wi-Fi Adapter  ($9.98 @ Amazon)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  ($29.99 @ Amazon)
Other: OS ($20.00)
Other: Usb3 to USB 2 ($0.01)
Total: $1008.24
Generated by PCPartPicker 2014-07-25 12:06 EDT-0400
So im building this build for an old buddy of mine and im wondering if this is all around compatible? Specifically the xeon and the mobo
https://linustechtips.com/topic/186616-all-parts-compatible/
Yeah the xeon fits in LGA 1150, but why choose the Xeon?
CPU: Intel Core i7 4770 | Motherboard: Asus Z97-A | RAM: 8gb (2x4gb) Corsair LP @1600mhz | GPU: Asus TUF GTX 1660 OC 6GB | Case: Fractal Design Define R4 | Storage: 250gb Samsung 840 EVO and 1TB WD Black 7200rpm | PSU: Corsair CX750M | Display: Asus VG245H 1920x1080 | Cooling: Cooler Master Hyper 212 EVO and default case fans | Laptop: Early 2015 13" Macbook Pro Retina - i5 2.7Ghz - 256GB SSD
https://linustechtips.com/topic/186616-all-parts-compatible/#findComment-2510711
he plans on doing some workstation stuff and gaming so the xeon is a pretty good choice
https://linustechtips.com/topic/186616-all-parts-compatible/#findComment-2510722
So long as the motherboard will have BIOS P 1.60, yes.
https://linustechtips.com/topic/186616-all-parts-compatible/#findComment-2510724
Price/performance, use case, etc.
They cost what an i5 4690K costs, but perform like an i7 4770.
https://linustechtips.com/topic/186616-all-parts-compatible/#findComment-2510730
https://linustechtips.com/topic/186616-all-parts-compatible/#findComment-2510734
You may need to update your BIOS for it to work.
Personally I wouldn't have gone with a Xeon, you might be missing out on some features, and believe me or not, the IGPU is still pretty useful even if you have a dedicated GPU.
EDIT: it would appear that I am blabbering nonsense, according to ARK Intel this CPU does have an IGPU, and even Quick sync. It doesn't however have hyper threading.
To say it performs like a 4770 is not entirely true, if a program is ably to use 4+ treads you are at a loss.
Case Bitfenix Ghost, Mobo Asus Maximus VIII Ranger, CPU i7 6700K @4.2 Ghz cooled by Arctic cooling Freezer i30, (barely). GPU Nvidia GTX 970 Gigabyte G1 @1519Mhz core, RAM 16Gb Crucial Ballistix CL16 @2400Mhz. SSD 128GB Sandisk Ultra Plus as my OS drive. HDD's  1TB  Seagate ST31000524AS its OEM, 3TB Seagate Barracuda, 2x 500GB WDC Blue (RAID 0)
If it isn't working absolutely perfectly, according to all your assumptions, it is broken.
https://linustechtips.com/topic/186616-all-parts-compatible/#findComment-2510744
This Xeon would appear to not have hyper threading though, the 4770 is much better in that sense, only if no programs used 4+ treads.
https://linustechtips.com/topic/186616-all-parts-compatible/#findComment-2510794
It's basically an i7 (a bit slower clockspeeds) but at i5 prices. if he is doing multithreaded operations it's a great budget CPU, also has some workstation features.
Check if the bios is updated out of the box, if it is, the system sounds pretty good.
One advise, go with a better wifi adapter, you don't want bad wifi, specially 2.4ghz wifi, as it interferes with everything these days. If your router supports dualband (5.0Ghz) get something like this http://www.newegg.com/Product/Product.aspx?Item=N82E16833166046
https://linustechtips.com/topic/186616-all-parts-compatible/#findComment-2510797
Tell me this is not the same CPU. For here it is stated that this CPU only has 4 cores and 4 treads, meaning no hyper threading.
https://linustechtips.com/topic/186616-all-parts-compatible/#findComment-2510824
Other: OS ($20.00)
Total: $1008.24
How is the system to be used?
The Xeon is listed as compatible from BIOS P1.6 which was released in December 2013. You may want to check with the merchant to insure that the motherboard ships with that BIOS if you don't have a compatible cpu so the BIOS can be flashed.
I take it the budget is tight. But an ssd and hdd would be much better than the hybrid.
I guess you've gone with 1x8GB to allow for a future memory upgrade. If that is not likely to happen in the near future (12-16 months) I would suggest changing to a 2x4GB kit to improve performance by enabling dual channel memory operation.
I am not sure that a 160 mm psu and the gpu will fit in the case. Antec lists the maximum gpu length at 317.5 mm. The Sapphire R9 280X is 262mm long. This leaves 55.5 mm. The psu mounts on its side and is 86 mm high. It would be better to be safe and go with a 140 mm psu.
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive  ($54.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($50.40 @ Amazon)
Video Card: Sapphire Radeon R9 280X 3GB Dual-X Video Card  ($269.99 @ Newegg)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($64.99 @ Amazon)
Other: OS ($20.00)
Total: $1050.64
Generated by PCPartPicker 2014-07-25 12:39 EDT-0400
BTW the cpu only runs 4 threads http://ark.intel.com/products/80917/Intel-Xeon-Processor-E3-1226-v3-8M-Cache-3_30-GHz. If you want 8 threads you will have to spend a little more and get Intel Xeon E3-1230 V3 (http://ark.intel.com/products/75054/Intel-Xeon-Processor-E3-1230-v3-8M-Cache-3_30-GHz?q=e3-123).
https://linustechtips.com/topic/186616-all-parts-compatible/#findComment-2510897
 mistaken it with the E3 1240 V3, he should step up the hyperthreaded one if he is using the CPU for workstation tasks that benefit from several threads.
https://linustechtips.com/topic/186616-all-parts-compatible/#findComment-2510940
