I'm debating going for a watercooling loop, but one of the things I'm getting hung up on is the ability to re-purpose the components. Aside from the pump, reservoir, fittings, and radiators, it isn't as clear whether the CPU and GPU blocks can be re-used for newer components.
Maybe someone can shed some light on this? It seems unlikely that the GPU blocks could be re-used on a new GPU, but more likely that the CPU block could be re-used in the event of a socket change.
I do not feel obliged to believe that the same God who has endowed us with sense, reason and intellect has intended us to forgo their use, and by some other means to give us knowledge which we can attain by them. - Galileo Galilei
Build Logs: Tophat (in progress), DNAF | Useful Links: How To: Choosing Your Storage Devices and Configuration, Case Study: RAID Tolerance to Failure, Reducing Single Points of Failure in Redundant Storage , Why Choose an SSD?, ZFS From A to Z (Eric1024), Advanced RAID: Survival Rates, Flashing LSI RAID Cards (alpenwasser), SAN and Storage Networking
https://linustechtips.com/topic/186206-migrating-loop-between-sockets-gpus/
GPU blocks generally cannot be reused on newer GPUs. CPU blocks on the other hand can assuming the manufacturer provides support via a bracket or mounting mechanism.
▶ Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning. - Einstein◀
Please remember to mark a thread as solved if your issue has been fixed, it helps other who may stumble across the thread at a later point in time.
