ram usage problem
Go to solution Solved by squirrl,
32bit is your issue. You need to install a 64bit OS to use over 3/4GB RAM.
hi today i reinstalled my windows(32bit) and i saw that my computer is using only 3gb out of 8gb ram. I looked at resource monitor and i saw that 4.9gb ram is reserved for hardware usage :
i tried msconfig max memory unchecking it didnt work. So if anyone can help me fix it, it would be very nice. (bad english because its my second language).
https://linustechtips.com/topic/186087-ram-usage-problem/
Aragorn (WS): 250D | 6800k | 840 Pro 512GB | Intel 530 480GB  | Asus X99-M WS | 64GB DDR4 | Corsair HX720i | GTX 1070 | Corsair H115i | Philips BDM4350UC 43" 3840x2160 IPS
Gimli (server):  Node 304 | G4560 | ADATA XPG SX8000 128GB | 2x 5TB WD Red | ASROCK H270M-ITX/AC  | 8GB DDR4 | Seasonic 400FL
 Omega (server):                 Fractal Arc Mini R2 | i3 4130 | 500GB Maxtor | 2TB WD Red : Raid 1 | 3TB Seagate Barracuda | 16GB RAM | Seasonic G-450w
Alpha (WS): 900D | 4770k | GTX 780  | 840 Pro 512GB  | GA-Z87X-OC | Corsair RM 850 | 24GB 2400mhz | Samsung S27B970D 2560x1440
https://linustechtips.com/topic/186087-ram-usage-problem/#findComment-2502526
Is there any other way to fix this issue rather than installing 64 bit windows ??  :mellow:
It's not really an "issue" as such. The main reason for there being 64bit operating systems is basically for handling more memory.
https://linustechtips.com/topic/186087-ram-usage-problem/#findComment-2502878
