water cooling and a titan? have fun with that budget.
you wont be able to have a custom loop with out spending more but heres a pretty boss build
http://pcpartpicker.com/p/YYec
or this one
http://pcpartpicker.com/p/YYf6
anyone feel free to say something different but it seems pretty good to me and if he wants to get a custom loop later he can easily to
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/18604-help-with-build/#findComment-217305
the amd 8 core fx is a very good cpu to pick its olny about $180 ish
ya i didnt even make a amd build (im not good with amd builds they never seem to be balanced :)
https://linustechtips.com/topic/18604-help-with-build/#findComment-217325
or this one
that's quite a beast!
https://linustechtips.com/topic/18604-help-with-build/#findComment-217326
thanks. and like i said later he can water cool it
https://linustechtips.com/topic/18604-help-with-build/#findComment-217331
Well its titan or watercooling with his budget
Christopher Kruse | Webdeveloper (Interface & Applications)
i7 3770k (3233C Batch) @ 4.2ghz | Asus P8Z77 WS | Gigabyte 780 Ti OC  | Corsair Vengeance LP 1600 32GB DDR3 | Samsung 850 EVO 500GB +2x Samsung 840 EVO 250GB + Samsung 830 256GB + 4x WD30EFRX, 2x WD30EZRX, 1xWD20EARS | Corsair AX750 + Bitfenix Extensions | Fractal Design Define XL R2 + Xigmatec 3in3 Hotswap Cage | Noctua NH-D15 + Thermal Grizzly Kryonaut, 5x Noctua NF-P14s redux-1500 PWM | Peripherals: Logitech G502 + Corsair K70 RGB + Red 40A-L O-Rings | Sound: Denon AVR 2807 via HDMI + 2x Nubert nuPro A-20 + 1x B&W CC6 Center | SoundMagic E10 | Jabra Speak 410
https://linustechtips.com/topic/18604-help-with-build/#findComment-217352
If you plan on getting a bunch of games, maybe consider a 7990 instead of a titan and you'd get 8 games (including crysis 3) for free.
Main rig: i7 3770K @ 4.54, Sapphire R9 290, Sabertooth Z77, 16 GB Mushkin Redline 2133, Lian Li PC-P50R, Seasonic 860xp Platinum, Kingston Hyper X 3K 240GB
freeNAS server: AMD Athlon II 170u 20W, 5 x 3TB WD Red in raid-z1 (12 TB)
media centre: AMD A10-5700, crucial M4 (boot), running XBMC,4 x 3TB WD Red, 3 x 3TB WD green + 2TB green in FlexRAID (17 TB)
https://linustechtips.com/topic/18604-help-with-build/#findComment-217491
