USB Device does not autoplay
Tazman192
Hey.
I've just come across an error which is quite frustrating. I use a Sandisk Cruzer Extreme USB 3.0 32gb flash drive. When I plug the flash drive in, autoplay does not come up however the flash drive shows up on My Computer, but not Device Manager. It does not show up on the tray (the "Safely Remove Hardware" icon), but other USB flash drives do. The drive is fully working and I can transfer files to and from the drive, I just cannot autoplay nor eject the drive safely.
I've done the obvious such as ensuring autoplay is enabled, formatting the drive, trying different ports, and now I'm not sure what the problem can be.
I've observed that it's only the first  USB port on the front panel that has this problem, but all other USB drives autoplay fine on this port.
Any help would be good, cheers.
"The only person you are destined to become is the person you decide to be."
CPU: Intel i5 4690K - Motherboard: Asus Maximus VII Ranger - RAM: Corsair Vengeance LP - 2x4GB @ 1866Mhz - GPU: MSI Twin Frozr GTX 770 4GB - CPU Cooler: Be Quiet! Dark Rock Pro 3 CPU Cooler - PSU: EVGA SuperNova G2 750W - Storage: Seagate Barracuda 2TB HDD- Case: Fractal Design Define R4 Windowed (with Red AKASA Led Strips) - Display: Benq GL2460HM 24" Monitor
Reinstall drivers for USB.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
I don't remember installing any USB drivers - just chipset. I can't seem to find any drivers for just USB on my motherboards website.
I can find drivers for USB 3, if that Maximus Ranger still is your mobo, but they are for win7. I think its driver issue as UBS3 ports aren't so compatible as older USB2's.. But I don't know if compatibility should be better in Win8+ as there aren't any drivers.
Yeah I'm still running that mobo, but I'm on windows 8.1
