Would air cooling on the H440 default fans be a good idea?
darth_bubbles
The default fans are 3 x 120mm FN V2 Fans and 1 x 140mm FN V2 Fan.
Is that enough? I will not be overclocking until I buy a watercooler for my CPU. That's why I don't want to buy more fans, because my next purchase will be a CPU watercooler. Thanks!
wait a minute. I could just get a watercooler for the CPU right away. What one should I use? Not over $90 please
You'll give your computer some issues but you can do it :P  if it starts to heat up don't be afraid to take the sidepanel or Front facade off.
5820k4Ghz/16GB(4x4)DDR4/MSI X99 SLI+/Corsair H105/R9 Fury X/Corsair RM1000i/128GB SM951/512GB 850Evo/1+2TB Seagate Barracudas
I realised that if I'm going to buy a cpu aircooler in the first place, I might as well just get a watercooler instead. What one should I use?
http://pcpartpicker.com/part/corsair-cpu-cooler-h100i
http://pcpartpicker.com/part/corsair-cpu-cooler-h80i
Those are two well known AIOs from Corsair :P
It will be fine but I'd personally stick at least one fan in the top to exhaust hot air, otherwise the air just lingers as there is such a small gap to escape from.
Motherboard: Gigabyte Z97X-Gaming 7 .:. Processor: Intel Core i7-4790k @ 4.7GHz .:. Graphics Card: MSI GTX 770 Twin Frozr OC 2GB
Storage: 1x 250GB Samsung 840 Evo, 1x 1000GB WD Blue .:. RAM: 4x4GB G.Skill RipjawzX 2133MHz .:. CPU Cooler: Cryorig R1 Ultimate
Case: NZXT H440 Black/Red .:. PSU: Corsair CX600M .:. Fans: 5x 120mm AeroCool Dead Silence, 1x 140mm AeroCool Dead Silence
I switched back to stock fans (from Aerocools 3x in front and 2 x top exhausts and 1 x rear exhaust) in my h440 today whilst I await the arrival of some new fans (3 in front, 1 in back). Temps increased by approximately 6 degrees on load. Idle was only a couple degrees hotter, but over the course of the day that too became 5-6 degrees hotter; th hot air, once its there, doesn't shift out quick enough. As above, you need more exhaust than provided as stock for decent cooling.
I air cool on my h440, and temps are fine. CPU never goes above 65 degrees and GPU never surpasses 80 degrees
CPU -AMD R5 2600X @ 4.15 GHz / RAM - 2x8Gb GSkill Ripjaws 3000 MHz/ MB- Asus Crosshair VII Hero X470/  GPU- MSI Gaming X GTX 1080/ CPU Cooler - Be Quiet! Dark Rock 3/ PSU - Seasonic G-series 550W/ Case - NZXT H440 (Black/Red)/ SSD - Crucial MX300 500GB/ Storage - WD Caviar Blue 1TB/ Keyboard - Corsair Vengeance K70 w/ Red switches/ Mouse - Logitech g900/ Display - 27" Benq GW2765 1440p display/ Audio - Sennheiser HD 558 and Logitech z323 speakers
