Recently my Moto X has been acting up. I purchased the device at the end of last year. It has worked flawlessly. Touchless Controls are really nice. But I am not hear to make you buy this phone. My problem has come up in the last couple of weeks. The problem being is that I cannot connect to my home WiFi. I have the password correct, but when I get home and try and connect it wont work. I will say "Connecting" and then the network will disappear like it is out of range. And when I try again it will be there but say "Not In Range". I can however connect to other networks like at stores and such. All of the other device in my house work fine on the network. I have checked my router to make sure the MAC address was not blacklisted, gave the device a static IP on the router, restarted and reset the router, restarted and factory reset the phone, tried WPS. I forgot the network and tried to reconnect, still nothing. Nothing has fixed it. I googled the problem like we all do, and there has been many topics on this. But none of the fixes I found worked. Any suggestions, maybe Warranty
https://linustechtips.com/topic/185294-moto-x-wifi-problems/
