drive partitions ? help!
Solved by DaveSimonH,
I see that the C: drive is labelled as NEW OS, have you just installed/reinstalled w8? If so, any reason why you didn't install it to the SSD? Is this a recent change, did you only see drives C: D: & G: before?
Generally when installing Windows at least one system reserved partition will be created (w7 100MB, w8 350MB), but usually you can only see it in Computer Management;
right click Computer on desktop, or in start menu & select Manage and then Disk Management.
Best not to delete them, you can hide them though. In Disk Management, right click one of the partitions and select Change Drive Letters and Paths, then hit Remove button to get rid of its drive letter. Now it will be hidden from view, but will still accessible by the system.
The Recovery Image is as it sounds, it's an image of your system created either by you with Windows Backup, or the OEM. Will allow you to take your system back to factory settings if you ever run into problems.
