Hi guys. I just get an h100i and the pc doesn't boot up if the link cable (usb) is connected to the mobo.
When I push the button the fans start running everything looks ok. But after a while it just stops and restarts again and again.
When I pull it out it turns on without a problem, when Im in the windows I can connect the cable and its working.
https://linustechtips.com/topic/185114-h100i-problem/
that sounds like you need some corsair professional technical advice.
if you plug another USB device (case I/O) to that port, do you get the same interference?
if so, contact the mobo manufacturer.
if not, then contact corsair.
https://linustechtips.com/topic/185114-h100i-problem/#findComment-2490886
