Chrome developer tools (or probably the developer tools in your chosen browser) are good for this. You can inspect the HTML and it will tell you on the right hand side all the CSS which is associated with the highlighted element... it even tells you which file it is in.
If it is bootstrap itself, best thing to do is to define your own class and add it to that element (at the end of the list of classes), it should override others.
Change properties of following class: navbar-inverse
You can easily find this with the developer tools of your browser! Right-Click -> Inspect element (at least in Chrome and Safari)
.navbar-inverse{background-color: #YOURCOLORHERE;border-color: #YOURCOLORHERE;}
Business Management Student @ University St. Gallen (Switzerland)
HomeServer: i7 4930k - GTX 1070ti - ASUS Rampage IV Gene - 32Gb Ram
Laptop: MacBook Pro Retina 15" 2018
Operating Systems (Virtualised using VMware): Windows Pro 10, Cent OS 7
Occupation: Software Engineer
