Pump/tube problem
Solved by Inori GC,
Getting a pump top like this one can solve your problem I think
http://specialtech.co.uk/spshop/customer/EK-CSQ-D5-X-Top-for-Laing-D5-Pumps--Acetal-pid-16019.html
You can then use your fittings that are designed to be used for hard tubing.
Playgb2 ·
Posted in Troubleshooting1 -
1
1
5
kasdashd ·
2
6
Ishikudeska ·
Posted in New Builds and Planning2 -
play_circle_filled
Latest From ShortCircuit:
