Could i use a dedicated mic, mount it to my wall and then buy a pair of nice, audio headphones? Because you can get really nice qulity Audio only headphones as nice as A40's for like half the price, then buy a realitivley cheap mic and screw it to the wall.
† TTCF Member † Jesus loves you! Have a good day and stay techie!
https://linustechtips.com/topic/183868-audio-question/
Ya i have a mechanical keyboard soooo. Well would you guys recommend some good headsets? That are nice? I dont wanna spend to much like $100? Right now i have wired turtle beach x12's from my old xbox and they hurt like hell.
https://linustechtips.com/topic/183868-audio-question/#findComment-2470874
I'd say get what you want headphone wise and slap that newer modmic on it.
https://linustechtips.com/topic/183868-audio-question/#findComment-2470881
Remember to quote
So I would say get the ATH m30x for $70 and the CAD u1 for around 25 - 30 dollars I know a friends who uses it to record and its pretty good and it includes a stand.
Edit: You might want to slap the modmic on these headphones
Fedex Ground must be on Horse back, It took 7 days to go 200 miles
https://linustechtips.com/topic/183868-audio-question/#findComment-2470886
Remember to quote
Ok thanks.
https://linustechtips.com/topic/183868-audio-question/#findComment-2470889
an a dedicated mic isn't? I mean if that's the case go for that, unless you like a headset suggestion that is given here.
Good point. It just seems alot to pay for what it is.
https://linustechtips.com/topic/183868-audio-question/#findComment-2470928
Actually the modmic 4 might sound better than a cheap stand alone watch the review Linus has a sound quality test
Ya just watched it and it seems kind of kewl. I might have to look into it.
https://linustechtips.com/topic/183868-audio-question/#findComment-2470955
