Hey guys, i wanted to buy a pair of over the ear headphones and i was wondering if you guys had any suggestions for a pair under $50. Thanks :)
 CPU: AMD FX-6300     COOLER: Hyper 212 EVO    MOBO: ASUS M5A97 R2.0    RAM: Team Vulcan 8Gb (4Gb x 2) , G-Skill Sniper (4Gb x 2)    PSU: Rosewill HIVE-750w    GPU: ASUS HD 7790 2Gb OC    CASE: NZXT Phantom 410    STORAGE: WD Black 1Tb , Intel 530 120Gb     AUDIO: HyperX Cloud , Sennheiser HD 518 , Audio Technica ATH-M30 , Sennheiser MM30G , Yamaha RX-V361 , Pioneer SP-BS22     PHONE: Samsung Galaxy S7 Edge     PERIPHERALS: Razer BlackWidow Ultimate Classic , Logitech g502 ( Thanks Syntaxvgm <3 )
https://linustechtips.com/topic/183827-over-ear-headphone-help/
The ZX600 by Sony are $80 (Directly from store.sony.com) and the ZX310 are $40.
I have both, the ZX310 are a little less sharp in the mid-range, and their quality is reduced.
I would recommend the ZX600 because it is so much more, but if your price is tight, in-ear for $50 may have better audio quality.
5800X3D - RTX 4070 - 2K @ 165Hz
https://linustechtips.com/topic/183827-over-ear-headphone-help/#findComment-2470329
Ola Englund does not approve of your hashtags. Sleep is for the weak, insomnia builds character.
As you are reading this you are slowly traveling forwards in time to where you will get out of the time machine and continue to read posts. Too spookyfor100me.
https://linustechtips.com/topic/183827-over-ear-headphone-help/#findComment-2470331
http://www.amazon.com/Sennheiser-HD-419-Headphones-Black/dp/B005N8W1MO/ref=sr_1_1?ie=UTF8&qid=1405831114&sr=8-1&keywords=sennheiser+419
Sennheiser 419s are pretty fantastic. I would highly recommend them. I've had mine for a few months and I have no complaints.
https://linustechtips.com/topic/183827-over-ear-headphone-help/#findComment-2470393
