Hey guys I recently upgrade my CPU to a A8-6600k I am wondering if after running prime95 for 10mins that the temps I am reading are correct? I dont know if i am reading it right or wrong but the package temps are really high but the CPU temp is fiine?
A8-6600k stock cooler
Asus F2A85-m
12gb ram
2tb
gtx560
AMD A10-7850k, Cooler Master 212 EVO, Team 2133 2x4gb, V300 120gb, DVD, 3 HDD, MSI A88X-G43, Asus Strix GTX 970, EVGA Super Nova G2 850watt, Acer B326HUL
https://linustechtips.com/topic/183782-cpu-temps/
That is no where close to fine. A 123 degrees is just dangerous. I suggest you make sure that the cooler is attached properly, even tho is is a stock cooler the temps shouldn't be that high. Also your voltages are through the roof, I suggest going into the bios and lowering them dramatically
https://linustechtips.com/topic/183782-cpu-temps/#findComment-2469691
the cooler is properly attached exactly how the other one is and others I have done. Also in the bios using Asus ez utility I have it set on performance.
with prime95 off im around 70c
https://linustechtips.com/topic/183782-cpu-temps/#findComment-2469703
I tend to not use the proflies supplied by ASUS. Go into the actual settings of the bios and have a look at the voltage, try setting it to at the very most (on stock cooler) 1.25 - 1.3
https://linustechtips.com/topic/183782-cpu-temps/#findComment-2469719
cpu temps are fine the board is not tho
https://linustechtips.com/topic/183782-cpu-temps/#findComment-2469736
Temps are fine!?! Am I reading wrong?? Cause from what I see it says Current: 113 Degrees Celcius, Minimum: 53 Degrees Celcius, Maximum: 123 Degrees Celcius
Unless i'm retarded
molNyvL.png?1
35C is very good temp for any cpu.... I'm not sure why under the package temps are for but. it doesn't look like a normal read to me.
https://linustechtips.com/topic/183782-cpu-temps/#findComment-2469883
Oh makes sense, I was purely basing everything off the package temps.
I was to. What are the package temps?
https://linustechtips.com/topic/183782-cpu-temps/#findComment-2476972
Good to see that you got a new cpu cooler, that cooler is very good in general. In the future, try using a different temperature software. I personally use Core Temp which you can try http://www.alcpu.com/CoreTemp/
Thank you, I cant seem to get alcpu to read current temps?
https://linustechtips.com/topic/183782-cpu-temps/#findComment-2482885
