Need help with RAM.
Go to solution Solved by seiny,
You check the manufacturers website, search the model number.
So I was looking at RAM on Scan and saw in the title of this RAM that it said it was dual channel -> http://www.scan.co.uk/products/8gb-corsair-ddr3-vengeance-low-profile-jet-black-pc3-12800-(1600)-non-ecc-unbuffered-cas-9-9-9-24-xm
But then in the description it says it is single channel. I am really confused, is it dual channel or single channel?
The blue version of this same RAM says dual channel in it's description so I'm wondering if it is a typo on the black version.
Thanks,
Blueprint
Intel i7 4790k / MSI Z97M / Hyper 212 Evo / MSI Twin Frozr GTX 770 / 16GB Corsair Vengeance 1600MHz / Fractal Design Arc Mini R2 / Corsair CS750M / Samsung 840 Evo 250gb SSD /  WD Blue 1TB
https://linustechtips.com/topic/183619-need-help-with-ram/
Ah ok cheers. I found out now and it is dual channel. Thank you. :)
https://linustechtips.com/topic/183619-need-help-with-ram/#findComment-2467470
