I have the xfx 7870 core edition. The fan is really quite bad and I was wondering if it is worth it to upgrade to an aftermarket cooler and which one? Thanks in advance
FX-6300 @ 4.1 MHz; Cooler Master Hyper 212 Evo; XFX Radeon 7870 Core Edition; Arock 970 Extreme 3; Corsair CX600; Corsair Vengeance Blue 8GB(2x4GB) DDR3 @1600MHz; Seagate Barracuda 1TB; Zalman Z9 Case
Asus U43F-BBA7; i5-460M @ 2.53GHz; Crucial 8GB(2x4GB) @1333MHz; Intel 520 120GB SSD
https://linustechtips.com/topic/18351-after-market-gpu-fan/
Id get this http://www.newegg.ca/Product/Product.aspx?Item=N82E16835186048
it will be a lot cooler and quieter than any GPU Cooler that comes with a card.
Intel Core I5 3570K @ 4.2Ghz w/ Hyper 212 EVO Gigabyte Z77X-UD3H 8GB Patriot Viper 3 1600Mhz CL9 Gigabyte Windforce 3X 7950 @ 1100/1550 Samsung 830 128GB Seagate Barracuda 1TB Fractal Design ​Define R4 Seasonic M12II 750Watt
https://linustechtips.com/topic/18351-after-market-gpu-fan/#findComment-215984
Would it be worth it though? or should I just save for a waterblock
https://linustechtips.com/topic/18351-after-market-gpu-fan/#findComment-217047
If you plan on water cooling your build I would save for a waterblock if not just get the aftermarket cooler that was suggested above.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/18351-after-market-gpu-fan/#findComment-217245
