ok so i have a old pc it is runing xp it is 64 bit and 4cor and it has netwerking probs and heat probs i was rhinking of puting a suver on it i am guna post a vid of what is hapeninf pls help allso if you play minecraft joun my suver when i get ir done
https://linustechtips.com/topic/18319-help/
Are you using the stock cooler?
    CPU: 3930k  @ stock                                  RAM: 32GB RipjawsZ @ 2133Mhz       Cooling: Custom Loop
MOBO: AsRock x79 Extreme9                      SSD: 240GB Vertex 3 (OS)                     Case: HAF XB                     LG 34um95 + Ergotron MX Arm Mount - Dual Review
  GPUs: Gigabyte GTX 670 SLI                     HDD: 1TB WD Black                                PSU: Corsair AX 860                               Beyerdynamic - Custom One Pro Review
https://linustechtips.com/topic/18319-help/#findComment-213629
