Ok so here is my issue which started about three weeks ago. I first got my pc back in March which worked fine until now. It was winter time back then and my pc was running Crysis 3, COD: Ghosts, Minecraft, AC4 and every other game perfectly fine with no issues at all. Then I realized when it started to get warmer my pc would get hotter and hotter. Back in the winter on my case the max the tempature ever went was 23.0C but now in the summer the max temperature it said so far was 35.3C. The only game I could run on my pc was Minecraft. Then when I tried to run COD: Ghosts 10 minutes into playing my pc reboots ( no BSOD or any error messages ) except the windows shutdown to prevent information loss and if I wanted to run in safe mode or normaly. Then when cleaning my pc to try and fix the problem I accidently pressed a button on the back called clear cmos and I had to reinstall windows, overclock and download drivers all over. Then I decided to take out the ram and put it back in it but only 12gb or ram would show up and not 16gb. So I put the ram sticks in one by one and I reliazed one of the ram slots didn't recognize my ram so kept the ram stick out of that slot and ran the pc and it showed 12gb of ram. My pc specs are: Intel I7 4820K 3.7ghz (Overclocked to 4.2) 16gb of Xpg Adata Ram 1000 Watt Raidmark PSU With 80 Plus Gold Msi GTX 770 2gb Asrock X79 Extreme 4 Motherboard 2Tb Western Digital Hard Drive 4 Case Fans Stock CPU Fan Also when not playing games my GPU is at 46C and when playing COD: Ghosts my processor highest temperature was 61C and my GPU highest temperature was at 81C. In the winter I had no problems at all so I don't know what the problem is now. All help is greatly appreciated and thank you in advance
https://linustechtips.com/topic/182736-pc-rebooting-help/
What cooler are you using for your CPU?
What case have you got?
What case fans are inside?
Is it hot in the room you play in?
Is your thermal paste applied correctly?
These are all contributing factors to CPU heat output and there are more.
CPU: Intel Core i7 4770K @4.5GHz - CPU Cooler: Corsair H100i - Motherboard: Asus ROG Maximus VI Hero - Memory: Corsair Vengeance Pro Red 8GB (2x4GB) @1600 - Storage: WD Green 2TB, 128GB Corsair Force Series SSD - Graphics Card: Asus MATRIX R9 280x OC Case: Corsair Graphite 600T - Power Supply: Be Quiet Power Zone 650W - Monitor: 2x Acer S240HLbid - Keyboard: Corsair K70 (Cherry MX Red) - Mouse: Perixx MX-2000 - Audio: Logitech G430, Logitech Z506
https://linustechtips.com/topic/182736-pc-rebooting-help/#findComment-2455853
Okay, explain to me why you had to reinstall windows because you clicked the "Clear CMOS button"? and when reinstalling how did you go about it, did you use any sort of software to wipe out the drives content before reinstalling?
I'll take a shot in the dark (ignore this if it is not what happened to you), you didn't wipe the drive because the "POST message" was that you have no OS installed correct? if this is correct then this is probably because of the SATA controller setting itself into AHCI mode, making it unable to detect an IDE based installation, meaning you probably have 2 installations of windows ontop of eachother on a single drive.
If this is the case, wipe the drive clean with Killdisk or any other drivewipe-software and reinstall windows.
This has happened to me in a previous build.
I'm ruling out the factor of it being the overheat protectiong because you didnt even pass 70.0C and the overheatprotection is usually set to 90.0C - 120.0C.
https://linustechtips.com/topic/182736-pc-rebooting-help/#findComment-2456737
