Ok so I keep getting a blue screen and I think it is when my my computer is under load if someone can tell me how to retrieve the blue screen i will post it
https://linustechtips.com/topic/182602-help-blue-screens/
Do stress tests if you think it is when your PC is under load. Prime95 and such. Things that will push your PC to max load.
What do they know of England, who only England know?
"Well that's what I always said I wanted to be remembered for, for being honest. Nothing else is worth a damn"
https://linustechtips.com/topic/182602-help-blue-screens/#findComment-2454049
I did one on my cpu and it did it again when 3/4 of my cores were hitting 90*c
I also do not think i applied thermal paste a few weeks ago that well because these are my temps with an i5 3570k water cooled with a h80i + my cpu decided it would overclock itself stupidly I mean I do have intel turbo boost on but that only made it go to 3.8GHz now it is hitting 4.2GHz which may be because I turned on GPU boost 2.0???  http://prntscr.com/43nv49
https://linustechtips.com/topic/182602-help-blue-screens/#findComment-2454103
