HDD problems....
By
jswag180
in Troubleshooting
in Troubleshooting
Solved by dragoon20005,
did you enable fast boot in the BIOS?
go to use BIOS to enable it and set your HDD to be the first boot drive
so I am correct to say you re install the OS into the WD Green drive.
WD Green are more of a storage drive
WD Blue are general use HDD
2
kerriya ·
Posted in Cases and Mods8 -
octester ·
Posted in Troubleshooting6 -
DavidPatrascu ·
Posted in General Discussion7 -
2
3
bill well ·
Posted in Peripherals1 -
4
play_circle_filled
Latest From ShortCircuit:
