I spend more than 6 HOURS on my PC: playing games, chating, having fun...
And after that i go out, but the problem is i'm having horrible headaches, my eyes hurt so badly!..
I don't drink too much, when im out!.
So is there any glasses for Protection from my monitor?
I JUST CAN'T STAY AWAY FROM MY PC!
https://linustechtips.com/topic/181723-i-have-a-big-problem/
take breaks?
Intel i7 4702MQ| Nvidia GTX 850M| Kingston 16GB DDR3 1600Mhz| Acer VA70_HW (mobo)| 1TB WD Blue| MATSHITA DVD-RAM UJ8E0|1600x900 display|Win 8.1
Intel i5 4690K @Stock| Sapphire 390 Nitro| Hyper X Fury 2x4GB| MSI SLI Krait z97| Noctua Nh-U12S | 850 EVO 256GB| 2TB WD Black | CM V 850w| Enthoo Luxe
If you want to tag me or any person with periods do: @[Member='Name]
https://linustechtips.com/topic/181723-i-have-a-big-problem/#findComment-2441233
Gunnars should do the trick. You can even get them with prescribed lenses.
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
https://linustechtips.com/topic/181723-i-have-a-big-problem/#findComment-2441239
Make sure the room is well lit. Turn down the brightness on the monitor too. Take regular breaks.
Some people get eye strain easier than others. I personally spend at least 6 hours every day on my computer with three monitors, most of the time without lights on and I only get sore eyes when they're all on a white screen for a few hours.
https://linustechtips.com/topic/181723-i-have-a-big-problem/#findComment-2441245
instead of spending money on Gunner Glasses try out the program F.lux. It does the same thing essentially as gunners.
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/181723-i-have-a-big-problem/#findComment-2441254
How to Turn down the brightness??it's not on my monitor, on my monitor there are only buttons for TV
https://linustechtips.com/topic/181723-i-have-a-big-problem/#findComment-2441261
no,no,no!!
that is not needed!
Ok then. Make sure there's adequate lighting in the room you're in.
My Setup:
Desktop
Main Laptop:
Thinkpad T420:
https://linustechtips.com/topic/181723-i-have-a-big-problem/#findComment-2441271
What does that program do?. and is it free?
It changes the brightness and contrast of your monitor depending on what time it is. It's helped me quite a lot with eye strain.
Quick and free install
https://justgetflux.com/
https://linustechtips.com/topic/181723-i-have-a-big-problem/#findComment-2441287
I'd recommend to try F.lux first and see how that does, it didn't work for me, but when I borrowed my friends gunnars they worked for me..
Senor Shiny: Main- CPU Intel i7 6700k 4.7GHz @1.42v | RAM G.Skill TridentZ CL16 3200 | GPU Asus Strix GTX 1070 (2100/2152) | Motherboard ASRock Z170 OC Formula | HDD Seagate 1TB x2 | SSD 850 EVO 120GB | CASE NZXT S340 (Black) | PSU Supernova G2 750W  | Cooling NZXT Kraken X62 w/Vardars
Secondary (Plex): CPU Intel Xeon E3-1230 v3 @1.099v | RAM Samsun Wonder 16GB CL9 1600 (sadly no oc) | GPU Asus GTX 680 4GB DCII | Motherboard ASRock H97M-Pro4 | HDDs Seagate 1TB, WD Blue 1TB, WD Blue 3TB | Case Corsair Air 240 (Black) | PSU EVGA 600B | Cooling GeminII S524
(Deceased) DangerousNotDell- CPU AMD AMD FX 8120 @4.8GHz 1.42v | GPU Asus GTX 680 4GB DCII | RAM Samsung Wonder 8GB (CL9 2133MHz 1.6v) | Motherboard Asus Crosshair V Formula-Z | Cooling EVO 212 | Case Rosewill Redbone | PSU EVGA 600B | HDD Seagate 1TB
DangerousNotDell New Parts For Main Rig Build Log, Señor Shiny  I am a beautiful person. The comments for your help. I have to be a good book. I have to be a good book. I have to be a good book.
https://linustechtips.com/topic/181723-i-have-a-big-problem/#findComment-2441340
I have installed it!. Let's see how it works.
Don't be surprised if your screen becomes very yellow. It's a bit jarring at first but after a while you won't notice it :)
https://linustechtips.com/topic/181723-i-have-a-big-problem/#findComment-2441373
