I have some visual problems with my current crossfire 2x MSI R9 280X.
It is not quite like the screen tearing that I know, but is more like the next frame is pushing away the previous frame upward, causing the bottom half of 1st frame, and the upper part of 2nd frame displayed together
   ______
a1          a1
a2          a2
a3_____a3
This is frame A, split into 3 parts
   ______
b1          b1
b2          b2
b3_____b3
This is frame B, also split into 3 parts
For what I know, screen tearing is
   ______
a1          a1
b2          b2
b3_____b3
Which while is quite disturbing, but my issue even worse
   ______
a3          a3
b1          b1
b2_____b2
Which make this bug very noticeable and makes me feel quite nauseatic
This is not the only issue, there are also several visual bug where several black boxes appear on the screen, when I watch videos on media player classic, green line appears on top of a web page(youtube), and quite some more.
I tried to remove one of the GPU, the issues persists but is much less noticeable and less frequent compared to when both GPU are used.
Any idea about the issue and how to solve it?
https://linustechtips.com/topic/181591-crossfire-issue/
   ______
a1          a1
a2          a2
a3_____a3
   ______
b1          b1
b2          b2
b3_____b3
   ______
a1          a1
b2          b2
b3_____b3
   ______
a3          a3
b1          b1
b2_____b2
are you on AMD driver ver 14.4?
can you swap display cables?
mind telling us the full spec of your PC?
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/181591-crossfire-issue/#findComment-2439442
I tried AMD 14.4, find the problem, and then roll back to the version recommended on the MSI page, which is 13.6, where the problem still persists.
I also tried the radeonpro, trying to tweak several of its options to no avail
I can't. My ASUS ML239H only allows VGA/HDMI input, and I am currently using DVI->HDMI cable provided in the LCD box.
Spec:
mobo = Gigabyte Sniper M5
CPU = 4670K
Memory = corsair low profile 2x4GB(cant find the exact name) 1600 mhz
HSF = Hyper 212X
PSU = NZXT 850Watt, Hale82 series
SSD = kingston ssdnow 120gb
HDD = WD black 1 TB
GPU = 2x MSI R9 280X gaming
https://linustechtips.com/topic/181591-crossfire-issue/#findComment-2439588
i VERY much doubt this, but it could be a lack of power? Probably not ?
Very much doubt that would be the issue, considering that I have attempted to go for 1 GPU for a while and the issue somewhat persists, though less frequent.
1 R9 280x + the other parts should never overload an 850 watt PSU.
Considering that there are many small issues like the problem with videos, I really want to try to swap the display with another, but I'll wait until I can eliminates other known possibilities, since this action may be either costly(buy), or a major hassle(borrow).
https://linustechtips.com/topic/181591-crossfire-issue/#findComment-2442579
yea i will suggest swapping with your friend a new monitor
can you try with just the onboard display?
just to verify if both GPUs are the trouble
how old are the GPU and are they used?
https://linustechtips.com/topic/181591-crossfire-issue/#findComment-2442729
Sadly I need to find some1 with 1080p display, which is not very common around me. most of my friends use laptop to game.
Or can I just use my previous ~720p display to check?
Before I use the crossfire, I was using the onboard graphics, HD 4600, and there is no issues except for the lack of graphic powwaaa
I RMA'd the GPU, so, very new, ~ 1 week old.
I have tried
  • going 1 GPU on both of the PCI socket on motherboard
  • Clear CMOS, flash latest mobo bios, all bios config on optimized default
  • flash new GPU bios
  • reinstall windows
, and the issue still persists...
https://linustechtips.com/topic/181591-crossfire-issue/#findComment-2444204
I have tried
  • reinstall windows
yea any monitor will do
its for troubleshooting
sounds like a hardware issue either the GPU (again) or monitor
https://linustechtips.com/topic/181591-crossfire-issue/#findComment-2444218
will try and post the result later.
Hmmm does this happen in every game? I ran two 7970's before and had a similar problem with a couple of titles. Usually I disabled CF, but in your case this really sounds like a GPU issue. Maybe RMA the 2nd one and test your GPU that you RMA'd before to see if it is the 2nd GPU. There are so many problems with CF.
The issue exist not only inside a game, but also on  youtube which is very bizzare.
The games I tried it on are Tomb Raider, and DOTA 2, both suffers the same issue, although on DOTA 2 the issue is much more vivid.
I will try RMA again eventually, but for now, I want to try out any other possible issue, since RMA will take quite a while.
https://linustechtips.com/topic/181591-crossfire-issue/#findComment-2444581
Tried an LG display at the same resolution, the same issue happens.
Now I think it is either the mobo's PCIe slot problem, or GPU, although GPU is questionable since this has been swapped..
Is there any software issue that will affect browsing / watching videos?
https://linustechtips.com/topic/181591-crossfire-issue/#findComment-2464415
disable hardware acceleration in flash
https://linustechtips.com/topic/181591-crossfire-issue/#findComment-2465957
I can't find the troubleshooting tab on display -> advanced properties, which seems to be necessary to disable it.Any other way I can disable hardware acceleration?
this setting is for adobe flash. Search for way to access flash settings.
https://linustechtips.com/topic/181591-crossfire-issue/#findComment-2471516
I don't get it, Should I find more about adobe flash or should I go for something else?
Cause I can't find any article that works on my pc T_T..
http://www.adobe.com/support/documentation/en/flashplayer/help/help01.html
https://linustechtips.com/topic/181591-crossfire-issue/#findComment-2472375
Oh god im so dumb..
I saw this before your post and it didnt work when I full screen a youtube video, alt+tab, and right click the task icon...
Now I realize i simply need to find a flash, right klik the flash window inside any url, and go to setting..
I've disabled it, and hopefully this will work.
Will report the result in few days
EDIT: I thought this would work, but 2 minutes in, and the issue resurface..
https://linustechtips.com/topic/181591-crossfire-issue/#findComment-2478048
