'No class registered', 'No interface supported'
Solved by Tsuki,
Run command promt as admin and type
FOR /R C:\ %G IN (*.dll) DO "%systemroot%\system32\regsvr32.exe" /s "%G"
and press <Enter>.
itll take some time, and slow shit down while it runs, some runtime errors will probably pop up, feel free to close them.
when its done, restart your computer.
what it does, is reregister the DLL files for explorer, should fix it.
