Laptop has multiple problems... (Need help pronto)
Solved by Yeelen,
Open it up and clean it as good as you can. The heating and dying problems might be a result of dust clogging up inside (laptops have a safety which kills power if it overheats). A new battery will probably fix the battery life issues. As for the startup freezing, try running a full scan and defragmentation on the hard drive, it might have some bad stuff on it.
Featured Topics
7
munem939 ·
Posted in Power Supplies1 -
5
1
6g2 ·
Posted in Troubleshooting0 -
NickKz ·
Posted in Programs, Apps and Websites5 -
