Logitech's Z-5300 system has holes in the tweeter feet for wall mounting. Probably wouldn't suggest getting "nice" speakers for wall mounting as they'll be bigger and heavier, thus more difficult to mount.
I think it's discontinued so you might have to buy used, however, I'm sure there's other models with similar features. I have a Z-5300 I may be convinced to sell...  :ph34r:
https://linustechtips.com/topic/180664-wall-mounted-speakers/#findComment-2433235
