So recently I connected an external monitor via the vga connection on my laptop. The monitor was able to run up to 1080p, but the gpu on my laptop can only go to 720p, so in my settings I set it at 720p.
I disconnected the monitor and I now can not revert the resolution on my laptop back to 1366x768 which is usually the max my laptop monitor can run at, haelp!
Here's a pic:
https://linustechtips.com/topic/180401-laptop-resolution-problem/
Are there any other options in the display tab?
