small upgrade
Go to solution Solved by SpyRosL,
I'm open for any advice! pls :)
I use $ so it would be more easy for you guys to understand the situation. I'm from E.U, the MAX LIMIT it can go would be there $800-$850
I'm sure both cpu's could open paint, vegas or even cs-x .. so I did said every day use.. and a rly high end gamic pc would do a perfect job in all that is out there. it doesnt rly have to be named gaming or working, cuz very few are working hard as hollywood desinger and s**t. about the oc, perhaps not right now..
hmm.. anything that you can suggest? pls do so.
I see.For editing i assume it's casual. I'd go with 8320 because it's an underclocked 8350 and maybe oc it to the 8350 standarts. Not necessary but saves money for the exact same performance.
As for the motherboard,you don't have to spend so much money on it because it doesn't affect performance at all. Look something in the 100e/$ price range.(ASUS M5A99FX PRO or GIGABYTE GA-990FXA-UD3).
Instead of the 270x,get the 270. Same cards but the 270 is underclocked. Again,overclock it a little bit(the easiest thing in the world and not necessary) and have the exact same performance with less money.
ADD A BIG ASS SSD IN THERE BECAUSE SSD IS LOVE!!
You wanted the best bang for your buck and you got it.
Hi,
..a friend is thinking to make a small upgrade on his old pc but the budged is quite  low. I wanna know which would do "best", price/performance for every day use.. btw there will be no oc'ing whatsoever. Don't be a fanboy pls. By getting this things he borrowed $300 from her sis alrdy! :D.. But tell me shall we do this or wait for new things if there will be any.
1.'cpu' - AMD FX 8350 --> 'mb' Asus Corsshair V Formula-Z --> 'gc' - r9 270x = $836.87
2.'cpu' - i5 4690k         -->'mb' Gygabyte X97X SOC              --> 'gc' - r9 270x = $934.85 + $97.98
https://linustechtips.com/topic/180289-small-upgrade/
The first one is the best bang for the buck, even though it is horribly balanced.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/180289-small-upgrade/#findComment-2421328
It's for gaming right?? What games specifically?
Lol at the motherboard.. SOC force and he doesn't wanna do overclocking????
 i5 3570k @4.all over the place || CM Hyper TX3 Evo || ASRock Z77 professional-m || 8GB G.SKILL Ripjaws Z 2400mhz CL10 || MSI GTX770 2GB OC'd 1280/3825mhz || ADATA SP900 128GB || Fractal Design Arc Mini R2 || Logitech G502 || Audio Technica ATH-M50
A spy is always better than a ninja!See burn notice. EVERYTHING is just a number!
https://linustechtips.com/topic/180289-small-upgrade/#findComment-2421347
Why not save some money on your mobo and get a better GPU.
CPU: Intel I7 4790K 4.8 Ghz || Mobo: ASUS ROG Maximus Hero 6 Z87 || Ram: Corsair Vengeance 16 GB 1600 Mhz || GPU: ASUS GTX 980 Ti STRIX || Storage: 2 x SSD Samsung 840 EVO 250 GB RAID 0 HDD Western Digital 1 TB Black || PSU: Corsair AX 860 watt || Cooling: 2 x AF 140mm (front), 2 AF120 Blue LED (bottom and back), 2 SP120 (top on radiator) ||  CPU cooler: Corsair H100i GTX || Case: Corsair obsidian 750D <3 <3 <3
https://linustechtips.com/topic/180289-small-upgrade/#findComment-2421405
They both aren't that great for the money, what is his budget? if you are in America http://pcpartpicker.com/p/j6VFbv
https://linustechtips.com/topic/180289-small-upgrade/#findComment-2421550
Eeh AMD or intel?
Intel : 4690k with an MSI Z97 Gaming 5. And for GPU stay with AMD go for the R9 280x or maybe a R9 290. Dont buy a reference. AMD cards are cheaper in my country.
https://linustechtips.com/topic/180289-small-upgrade/#findComment-2421591
https://linustechtips.com/topic/180289-small-upgrade/#findComment-2421695
Eeh AMD or intel?
hmm with what u have suggested it will cost me here.. around :D $1009.69 :D lol the r9 280x is $450
https://linustechtips.com/topic/180289-small-upgrade/#findComment-2421711
Then go with a 4690 or 4670. Not a K version. 450 that is expensive.
https://linustechtips.com/topic/180289-small-upgrade/#findComment-2421727
I could mention ssd, ram, cpu cooler etc, but we do alrdy have those you know. but thanks a lot for the suggestion.!!
https://linustechtips.com/topic/180289-small-upgrade/#findComment-2421777
Just making sure :P
https://linustechtips.com/topic/180289-small-upgrade/#findComment-2421809
Get an 8320, a decent 990FX motherboard, and a better video card (maybe a 280?).
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/180289-small-upgrade/#findComment-2422027
ok, rly thanks for that. So i ended up with fx 8320, ASUS M5A99FX PRO and r9 280 = $851.84
Much better. :)
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/180289-small-upgrade/#findComment-2422123
