Stuck on DRAM led
Solved by Incblob,
Only thing you need to do is find what is the cause of it not booting.
Do you not see any logos? like the MB logo etc
You could try each component on a different computer.
The fault could be the motherboard, maybe your short circuited it and fried the MB or something fell off or is bent.
i'll send it back for replacement, everything else is either new or stuff that worked fine on my previous build.
