Need some help in Pid!
Go to solution Solved by CornOnJacob,
Yep. I'm stuck there. I tried throwing beams and going up,  but there is insufficient space and it just goes sideways, and not downwards. (the beam ball). What should I do? How did you do it man!?
If you hold "down" while throwing, it should drop the beam directly beneath you. (If that doesn't work try "crouch" instead). The beam will lift you up and you can move to the right and continue.
Hey guys! So I was just playing Pid, and I was stuck at that Breaking the wall level. I mean, We had to take a bomb from a lady and then come down and then throw a  beam, and at last, press "d" and execute the wall by bombing it. I did it successfully, but now i'm stuck! After bombing, there's a small passage inside in which we have to bend and go inside, I did so, but then, what the hell is to be done? I can't even see the Kid in there! Here's a small Pic...
Incase you didn't understand something, head over to PM! :)
Just look to the left, above the big round circles. You'll find a leg. (pinkish shoes) That's the kid. But how do I go up there?!
Here's the Image:
 [spoiler=CORMAC]CPU:Intel celeron 1.6ghz RAM:Kingston 400mhz 1.99gb MOBO:MSI G31TM-P21 GPU:Will add one later on! CASE:local ROUTER D-Link 2750U, D-LINK 2730U MOUSE:HP,DELL,ViP KEYBOARD: v7 SPEAKERS:Creative 245  MONITOR:AOC E970Sw HEADSET: Sony MDRx05s UPS:conex ups avr 500va PSU:idk OD:Samsung super writemaster STORAGE:80 gb seagate+ Seagate 1TB OS:Windows xp sp3 themed to Windows 7 + Linux |Rest all pc in my house will be updated from time-time
COMING SOON
https://linustechtips.com/topic/179610-need-some-help-in-pid/
I've played it and beat that section just fine. Are you glitched into the floor/wall?
[spoiler=My Current PC]AMD FX-8320 @ 4.2 Ghz | Xigmatek Dark Knight Night Hawk II | Gigabyte GA-990FXA-UD3 | 8GB Adata XPG V2 Silver 1600 Mhz RAM | Gigabyte 3X Windforce GTX 770 4GB @ 1.27 Ghz/7.25 Ghz | Rosewill Hive 550W Bronze PSU | Fractal Design Arc Midi R2 | Samsung Evo 250 GB SSD | Seagate Barracuda 1TB HDD | ASUS VS239H-P | Razer Deathadder 2013 Partlist
LTT Build-Off Thread: http://linustechtips.com/main/topic/35226-the-ltt-build-off-thread-no-building-required/
https://linustechtips.com/topic/179610-need-some-help-in-pid/#findComment-2413670
I can't understand what you're saying, but yes. It's probably some kind of a glitch. Please help me man!
How did you do that anyways? Do you remember that place? So that you can compare my pic and yours?
COMING SOON
https://linustechtips.com/topic/179610-need-some-help-in-pid/#findComment-2414075
I don't really remember. I'll upload a pic soon.
EDIT:
If I'm correct, you should follow the red path in the picture, going up to the right to get the bomb then going down and left until you hit the green circle. As it stands, you are stuck inside the wall/floor inside the green circle?
https://linustechtips.com/topic/179610-need-some-help-in-pid/#findComment-2414120
EDIT:
COMING SOON
https://linustechtips.com/topic/179610-need-some-help-in-pid/#findComment-2414271
https://linustechtips.com/topic/179610-need-some-help-in-pid/#findComment-2414319
I'll try it tomorrow... BTW, What's crouch? Going while being down?
COMING SOON
https://linustechtips.com/topic/179610-need-some-help-in-pid/#findComment-2414354
Sorry, shows how much I remember :P. I think you're right--there is no separate "crouch" button.
https://linustechtips.com/topic/179610-need-some-help-in-pid/#findComment-2414664
Thanks :). It worked :D
COMING SOON
https://linustechtips.com/topic/179610-need-some-help-in-pid/#findComment-2420162
