Hi,
I'm around LTT YT channel for a while and it made me dream about new computer.
Following recommended Build Plan:
1. Budget & Location
550-650 Euro (if it makes significant change i am able to add 50)
Germany/Europe
2. Aim
This is going to be a base for future upgrade with Graphics card and maybe another display. With this upgrade I would like to be able to play games like Witcher 3. Ultra details etc. are not a target.
Without Graphics I want to play LoL and Witcher 2(if it's possible).
I plan to do some programming and this is probably gonna be my "media center".
I do not plan to overcock,
I do plan to multi OS boot
second drive is storage only
3. Monitors
ATM only one FHD, I am not planning to upgrade with 2k or 4k soon.
4. Peripherals
The only peripheral I have is mouse. OS prise is not included in Build prise.
Build 1:
CPU                   Intel Core i5-4570 3.2GHz Quad-Core                    €170.24
Motherboard    ASRock H87M Pro4 Micro ATX LGA1150               €65.72
Memory            Kingston HyperX Grey 8GB (2 x 4GB) DDR3-1600 €68.98
Storage            Seagate 1TB 3.5" 7200RPM Hybrid                         €74.99
                         Toshiba 3TB 3.5" 7200RPM                                      €93.80
Case                BitFenix Shinobi ATX Mid Tower                               €11.90
Power Supply XFX 450W ATX12V / EPS12V                                  €47.59
Monitor            Hannspree HE225DPB 21.5"                                   €107.89
Keyboard        Gigabyte GK-K7100                                                  €14.48
Total:  €655.59
Build 2:
CPU:                 AMD A10-6700 3.7GHz Quad-Core                         €114.90
Motherboard    Gigabyte GA-F2A88XM-DS2 Micro ATX FM2+       €49.89
Total:  €558.52
I know that Display, Keyboard, Case, PS are cheep, but unfortunately I try to get the most from the budget.
Is it worth investing in higher speed RAM?
Thak you for your advices and engagement.
https://linustechtips.com/topic/179222-base-for-future-upgrade/
Well... high speed RAM wont matter much for gaming. And if you plan to upgrade this with a dedicated GPU later on then you better have a 500-600W PSU instead, or else you will have to change the PSU as well.
Between the 2 build I would take the first. Look pretty solid to me except that I will change the 1TB to a 120GB SSD instead.
My rig: Intel Core i7 4790k | MSI Z97 PC Mate | GSKILL Ripjaws X 16GB 1866MHz | ADATA Premier SP550 480GB SSD | Seagate Barracuda 3TB | Seagate Barracuda 2TB  | MSI Gaming X GTX 1070 | Thermaltake Versa N21 | Corsair CX550M Semi Modular PSU | AOC G2460PF 144Hz | Logitech G502 | GSKILL Ripjaws KM780  | GAMDIAS HEPHAESTUS V2  PCPartPicker | Old Build Log | New Build Log
https://linustechtips.com/topic/179222-base-for-future-upgrade/#findComment-2407524
And what about this:
Build 2, with better CPU:
CPU:                 AMD A10-7850K 3.7GHz Quad-Core Processor     €142.69
Total:  €597.32
Is this as powerfull as Build 1(Intel i5-4570)?
What about Power vs Performance?
https://linustechtips.com/topic/179222-base-for-future-upgrade/#findComment-2413068
I think you can get a discreet GPU now in this budget that can fairly play games at 1080p at high setting or ultra with reasonable fps. If you can sacrifice the monitor, you can get a 750Ti and maybe use spare monitor (if you have one), if you don't just buy without the discreet GPU and save up so you can upgrade to a discreet GPU. So here is the parts i got for you bro :D
CPU: Intel Core i3-4360 3.7GHz Dual-Core Processor  (€148.19 @ Amazon Deutschland)
Motherboard: MSI H87-G43 ATX LGA1150 Motherboard  (€87.89 @ Amazon Deutschland)
Memory: Kingston HyperX Grey 8GB (2 x 4GB) DDR3-1600 Memory  (€68.98 @ Amazon Deutschland)
Video Card: MSI GeForce GTX 750 Ti 2GB TWIN FROZR Video Card  (€135.89 @ Amazon Deutschland)
Case: BitFenix Shinobi ATX Mid Tower Case  (€11.90 @ Caseking)
Power Supply: Silverstone Strider Essential 400W 80+ Certified ATX Power Supply  (€39.81 @ Amazon Deutschland)
Keyboard: Gigabyte GK-KM6150 Wired Standard Keyboard w/Optical Mouse  (€17.78 @ Amazon Deutschland)
Total: €611.22
"THE RED ARMY"
| INTEL i5 4690K | GIGABYTE Z97X GAMING 3 | XFX R9 390X | CORSAIR VENGEANCE PRO 4x2 8GB 1600Mhz | CORSAIR H80i | XFX XTR 650W | 1TB WESTERN DIGITAL CAVIAR BLUE | ADATA SP600 256GB | LOGITECH G502 | CORSAIR VENGEANCE 1400 | CORSAIR K70 MECHANICAL RED | NZXT S340 |
https://linustechtips.com/topic/179222-base-for-future-upgrade/#findComment-2413319
