Left Click Not Working
Go to solution Solved by Winkly,
There's nothing called Control Panel, so I went to gaming mice and downloaded the M65 firmware.
Any luck with downloading the newest firmware?
I have an M65 mouse from Corsair, and had it for about 2 weeks. Now, when I turn on my computer, when I left click, nothing happens, but when I right click it works. So I went to the settings and changed the primary button to right click, and now I can click normally, but when I left click, it doesn't bring up the right click menu. Any help?
https://linustechtips.com/topic/178717-left-click-not-working/
no he said that the button works
He didnt.
I'd get a replacement.
Specs are on my profile page
 Teach a man to fish and he ends up sticking a screw driver in a turned on power supply seeing if it still works.        #KilledMyWifeWithABomb            Resolution is just a number
https://linustechtips.com/topic/178717-left-click-not-working/#findComment-2399935
I tried it on my mom's Mac, and both the right and left click buttons work, so it's not a hardware defect, and also I ran a full scan with windows defender, and nothing was detected.
EDIT: The left click works a few seconds after booting, but then it stops working.
https://linustechtips.com/topic/178717-left-click-not-working/#findComment-2400009
Where can I find the Corsair Control panel? I've never heard of it.
Is a setting changed in the Corsair Control Panel? Could be that it works a few seconds after booting because the Corsair Control Panel hasn't started yet. Try to uninstall and reinstall and see what happens.
https://linustechtips.com/topic/178717-left-click-not-working/#findComment-2400370
After downloading the firmare, (here is a screenshot of the zip file: http://gyazo.com/c693668bd3dd64281c38c55e74b0a6d2), I ran the "M65 setup 1.0.0.11.exe" and now the mouse works fine! I can not thank you enough, Winkly!
https://linustechtips.com/topic/178717-left-click-not-working/#findComment-2400423
