Iam searching for like a new set/kit ( not literally ) of peripherals......
I use the peripherals on my laptop because i don't like using the laptop on board keyboard and trackpad for gaming
for the mouse this is what i'm considering :
Logitech G502-Razer DeathAdder ( any version ) - Corsair M45 - Corsair M65
for the keyboard this what i'm considering :
Ducky Shine 3- Corsair K70 - Logitech G710+
i don't know anything about gaming headset so.......recommend me :D
iam open for other suggestion
PS : the keyboard must be mechanical keyboard,must be using Cherry MX Switches, less than $ 120. AND you may asked me this : " but the Logitech G710+ is brown switches and cost more than $120 ? " well to answer that i have try that keyboard the other i haven't.. i had heard Cherry MX blues sound on the internet.
PS : the mouse must be less than less than $ 70 ( a little bit more is alright...who knows if in my country it's cheaper )
PS : ( this is for peeps search my history comment ) yes i said i already have razer deathadder..... but that is actually a question from+for my cousin
off topic : is a gaming headset worth to buy anyway ???
off topic : i played Sniper Elite V2, Hitman Absolution ( not that often playing this...) , CoD 4 Modern Warfare, Battlefield bad company 2, Payday the heist, Payday 2
THIS IS A PERSON THAT HAVE A LOT OF PROBLEMS :D
https://linustechtips.com/topic/178684-need-help-for-new-peripherals/
I would suggest Steelseries Siberia V2, the video tells you the rest  ;) (What was your budget for the audio?)
For mouse I personally think that you should go with the Razer Deathadder, because you play FPS games more often?( I am not a fan of Razer :lol: )
And last, but not least the keyboard. So Ducky Shine 3 sounds pretty appealing, but is it in the price range?
I have no experience about the Ducky Shine products, but I have heard some good feedback about the products.
So if you're still not sure, just watch the Linustechtips videos(which you have probably done) and read some customer reviews about the items.
(for example from the Amazon etc.)
"Hard work betrays none, but dreams betray many" - Hachiman Hikigaya
$40-$50 for the headset
Can't say much about the mouse stuff except that I would't buy any Razor product again because (in my case) they brake easily. The Deathadders mouse buttons stopped working like 3 months later. I ordered the G502 now, mainly because I was quite happy for more then 10 years now with their products except for their keyboards :D
For your keyboard choice I can only say that you need to think about what you need. The G710 comes with all this shiny stuff like USB port, media keys, volume wheel, macro keys and a fancy design. If you don't need all these and if you're focused more on quality than features I would recommend the DS3. I had both Keyboards and changed the G710 for the DS3 and didn't regret it so far. I can't say much about the Corsair keyboards because I never had one. But according to many forums they seem to be pretty decent but I would wait for the RGB mechanical keyboard.
If you're some sort of audiophile or if you really like good sound you should try a combo of proper stereo headphones and an external mic like the Zalman ZM-MIC1 or the ModMic 4.0. My Logitech G35 broke last week and I was about to buy the Steelseries Elite or another G35/G930 but then I decided to go for a pair Beyerdynamic DT770 headphones and the ModMic. Overall I paid like 50$ more than for the Steelseries Elite but the sound quality is way better than everything you will get from one of the gaming headsets. It maybe doesn't look as good but you won't be disappointed. You should really try out proper headphones and then decide. If you still want to get a gaming headset after that I would get the G35/G930 since the overall quality is acceptable compared to the gaming headcrap.
