i want to buy a new set of speakers but i'm block with uncertainty, that uncertainty is "Static noise"
this is how i found the problem, i have two pair of speakers, the one i am using right now only have one speaker that works its partner is dead, while the second pair, which my sister won in a contest, gives off static noise even when the computer is idling.
i tested my sister's speakers on my desktop, back and front audio ports, and it gives off static noise while the one im using does not.
can anyone explain this phenomenon?
i even tested it with my headphones which works perfectly on both ports.
https://linustechtips.com/topic/178451-speaker-problem/
What speakers are they.
try using the speakers on anouther device. Cd play if you have one.
well i use a Logitech speaker which i don't know what model number since it faded away and my sister's speaker is not in google, lol but it's a USB powered speaker.
i tried a different pair of speakers just now and it's a REALLY REAAAAAALLY old Genius speaker with an AMP, still gives off the same static noise like my sister's.
https://linustechtips.com/topic/178451-speaker-problem/#findComment-2396179
